Any alignment techs? Something bent or just bushing?
Old Nov 14, 2013 | 01:46 PM
mickey513's Avatar
Alignment sheet attached. Everything is in spec except the right caster, slightly out of spec ... looks like something maybe bent? Lower control arm or just the bushing needs replacing???
Old Nov 14, 2013 | 08:31 PM
paperboy42190's Avatar
No, you're fine. Caster isn't really an issue nor is it adjustable.
Old Nov 19, 2013 | 01:37 PM
mickey513's Avatar
Yeah, it's just slightly off but something needs to be replace to get in back in spec. Anyone?
Old Nov 19, 2013 | 02:01 PM
is it tracking straight?
caster is the angle of the steering axis according to the centerline of the wheel.
its normal for the right side to have a little less caster than the left side.
if its tracking straight, I wouldnt worry about the caster being .1 degree off.
caster will not ruin tires.
only toe will eat tires.
and your toe is set correctly.
Old Nov 22, 2013 | 03:57 PM
mickey513's Avatar
It's straight after the alignment but I noticed the setting don't tend to hold very long, maybe a couple of months at the most after a alignment. It's going in to the shop this weekend to get new front control arm bushings. I'm guess I'm going to leave it alone since it's probably not worth fixing.
Jul 16, 2017 07:33 AM
flybyglass
Sep 24, 2015 01:12 PM
Eggs999bacon
Sep 24, 2015 10:08 AM
Brandle34
Sep 23, 2015 07:20 PM
