Another TPMS Issue
Old 05-20-2010 | 10:57 PM
xavierhn's Avatar
Out of Rice
Another TPMS Issue
I read other threads regarding tpms but .... I bought 4 tpms from a member and got it installed at Town Faire Tire. I figure the tpms sensors should work automatically or so i read that what it should do; nonetheless, that annoying warning appears. Tires pressure are at required level. So I don't know what to do now. Should i unplug battery and see if it works. I have a base 06 TL, the TPMS were stripped from a '06 TL-S. Does it matters? Please help. I try to avoid the dealership as much as possible. Thanks for the help.
Old 05-21-2010 | 07:22 AM
Turbonut's Avatar
All the TL sensors are the same and will also fit a '05-'09RL, '04-'06 MDX. They should all read properly after a short period of time, but if one is bad, you'll need to have it checked. If it was working correctly before the install, then a sensor was either DOA or the tire shop damaged the unit during the installation process.
I'd call the tire shop to see if they have any equipment to read the DTC, if not, I guess it's going to be the dealer. I don't believe that you can't remove the trouble codes manually.
udelslayer
1G RDX Problems & Fixes
05-06-2016 01:27 PM
bailey24
11-21-2015 09:43 PM
johnalfa
10-31-2015 01:55 PM
lland
10-04-2015 05:47 PM
GhostTL09
09-19-2015 02:57 PM
