Am i misfiring?
Am i misfiring?
Recently it appears that my car may be misfiring. Typically it happens between 5000-7000 RPMs in vtec under wide open throttle and in first gear. It will run strong then do a spurt of 3 cutouts (almost like its bouncing off the rev limiter) then continue normal and sometimes jolt one more time. Does this sound like misfiring to you all and if it is what it typically the problem/fix?
Car is a 2007 TL Type-S 157,000 miles automatic.
I'm not very good with diagnosis but wouldn't a misfire happen even at idle? Transmission slipping? Low oil? Clogged cat?
This is my attempt at trying to help I'll let others chime in. Can you post a video?
check your oil level!
Jeff
YUP! This happens in my 03 Acura EL, its burns oil so when the oil is low the engine light will come on and the car wont go past 4k rpms. Top it up with oil and then it goes back to normal.
Extipsy
04-25-2016 08:29 PM
ncsaxguy
1G TSX Problems & Fixes
03-18-2016 12:47 PM
202009
01-23-2016 10:02 PM
