Airbag light on
Airbag light on
Just today my airbag light came on. Sometimes it goes away but most times it comes on and stays on. My question if anyone can help me is what exactly im i looking at here and how much is it going to cost me. Am i stuck with only the dealer? I ask since im out of factory warranty. Its an 05 auto. I am the second owner,68,000 miles and clean carfax to date. No accidents! Any insight would be appreciated as i obviously want my airbags working properly.
No you are not stuck with the dealer, any independent shop should be able to scan your TL.
Just to clarify you mean the actual AirBag light located in the middle of the dash or do you mean the SRS light? For the AirBag light the most common problem is generally the passenger seat weight sensor, which detects wether something/someone is in the passenger seat.
KBPftmfw
On my Mustang you can see the airbag modules by looking in the upper grill. The problem with this is they are exposed ti the elements and over time, they would corrode and the airbag light on the dash would come on. Sometimes, the airbag light would go on and off for periods of time, flicker, etc.
I know the TL protects the modules better but I would check for corrosion first.
BoricuaTL
04-08-2016 01:08 PM
EvilVirus
12-10-2015 07:38 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
