Airbag Indicator
Look in your nav messages. It should give you a diagnostic code so you can see what's causing it.
Yes, you should be concerned. Your airbag won't deploy if that indicator is on.
I had my indicator on and the code showed that my front right impact sensor was throwing it. I replaced the sensor and all is good now. My airbag indicator was intermittent.
SL33per (08-04-2015)
