Air bag code 4 slow flashes followed by 6 fast
My airbag light recently went on and i cant seem to turn it off, i did the resetting with the paper clip and it turned off but back ON next time i turned the car off and back on. So next i did the scanner plug test and here is the flash sequence of my problem, ANY HELP IS REALLY REALLY APPRECIATED:
THe impact sensors just don't go bad , You need to tell me what happen to the car recently. Well, sensors are everywhere. 2 in fronts which behind the front bumper. side impacts have 2 of each side. 1 for the seat, 1 for curtain airbag. So, the airbag light just come on w/o any incident recently?
there is a side impact under the carpet. You able to see it. If you take out the passenger sill and under the carpet you able to see the sensor. YOu can unplug and plug it back in. Then , do a reset procedure and check if you have damage any wire. Is your car under warranty?
HeloDown
Sep 8, 2015 06:51 PM
