Aftermarket AC Compressor Suggestions?
Hey guys! So my AC system apparently has suffered from the Black Death and is no longer blowing cold air. Since I only use my AC a few months out of the year, I don't want to invest the whole $1,400 (including labor) that I was quoted to replace the system. SO, I would prefer to save about $500 (or more) and get an aftermarket compressor and possibly other aftermarket parts.
Does anyone have suggestions on a specific brand or website to get these parts from? I need to check with the shop which parts I need and which ones I don't, but general suggestions would be great!
Thank you!
Thank you!
check the OEM supplier brand, they are fraction of the Honda part also they are the same compressor as OEM.
(If those two websites are what kind of thing you were referring to)
Akira'sPapa (06-04-2016)
https://www.amazon.com/gp/aw/d/B001U...=1&pc_redir=T1
There you go... just saved you almost $400 and its OEM exact part. Not aftermarket.
No problem with aftermarket so go to RockAuto and check the Denso and other units available, along with the other parts that might be needed.
Use code 896A54E1A1C600 for a 5% discount, good thru 9/14/16.
If the compressor internals have contaminated the system, better make certain it's cleaned, or the all parts are replaced, or the compressor may enjoy a short life.
The following 2 users liked this post by Turbonut:
Akira'sPapa (06-04-2016),
DMZ (06-04-2016)
What are you f'ers doing up so early on a Saturday?
Good info here, sub'd. My original 13.5 year old compressor is still running strong, but you never know. Thanks for the links and info
Most A/C systems will last a lifetime, but problems do occur. The daughter's Maxima has 255k miles and no problems, our '08 knock around car 235k miles, compressor a little noisy but running fine, etc, so good luck.
If and when the compressors disintegrates which happens occasionally, it is difficult to clean the various components, so better to do replacements, providing pricing is adequate, firewall forward. Also, make certain the amount of the correct oil is used in the new components.
Head a da Family
Go to rockauto and buy the original Denso A/C compressor (the very one our cars came with from the factory) for a lot less! Just under $200 last I checked.
I did when I had to replace mine a few years ago.
When the AC compressor in my IS300 shot, Lexus wanted $450 however I bought a Denso for $125. My AC is going all the time down here in Houston lol.
i agree denso is the best aftermarket compressor, but if you have the black death you will need to replace the condenser as well or you will blow up that nice new compressor ,
and flush the rest of the system , a new expansion valve would be a good idea also. system MUST be completely clean or you are wasting your money. and correct amount and type of oil.
Try this one..
#spoonfeeding
because this thread is for the 3G TL...
Try this one..Amazon.com: Denso 221-3236 Radiator: Automotive
#spoonfeeding
#spoonfeeding
Thanks for the link but that for a radiator I need an ac compressor. I have searched high low. I'm not sure denso made one for that year. I see ucd, four Seasons are either of those any good?
Just an update for everyone...
I got my compressor replaced with a DENSO from RockAuto and it worked great for about two months before failing once again... The shop did everything they were supposed to and I got a replacement part for free, which is now in my car... Unfortunately I was forced to pay for labor again, although the shop did catch me a break...
The shop said it was something wrong with the clutch on the part I think so hopefully it actually was just the part itself.
Praying that the replacement compressor actually works when I go to use the AC next summer
Yeah, they replaced everything you're supposed to like the condenser and drier and whatnot.. and did a system flush so I think it had to have been the part itself.
yody
02-24-2016 12:16 PM
dzionny_dzionassi
02-18-2016 11:45 AM
