Acuraziners chime in plz!
Whats up Aziners I tried doing my own research on this issue the last week. I want to bring the issue here to get some advice.
My Car: 07 Base
Story: I Took My Car to Jiffy Lube got an oil change they pointed out a hole in my intake boot. The Car was throwing these codes before oil change.
P145C
P0497 Evap Emission Low flow fault
Car still ran fine at this point
soon it started having rough acceleration and hesitation through the RPMs
I replaced the intake boot and air filter. That didnt help and the car is now having this code.
P0108 Map/Baro Circuit High Input car started all symptoms after this code.
Any help would be Appreciated before i take it to the Stealership Thanks.
My Car: 07 Base
P145C
keep it clean
Have you tried to reset your ECU after getting the intake boot fixed? Also, double check to ensure everything is nice and tight. Had a roomate that was getting a lot of air map codes from his Supra, and it turned out to be a loose intake clamp.
FYI: This will probably get moved to problems and fixes.
BANNED
^unhook your negative battery cable for a few minutes. then hook it back up.
Anything before the throttlebody will have no effect on the way the car runs. Only on a MAF car will it have an effect. The MAP sensor could easily make the car run bad. Unplug it and visually inspect first. If it starts throwing a lot of random codes, the battery and grounds are usually the first place to start.
Do you mean unplugging the battery?
mugen_kid
11-13-2015 10:38 PM
oyayjoe
09-12-2015 04:40 PM
