Acura TL problem
Old 01-09-2018 | 09:57 AM
climer55's Avatar
Acura TL problem
this morning i started my 2008 Acuca TL as usual but i noticed that the Auto windows was not working and A & B odometer was on 0 as if it cleared everything out. Wehn i got to my destination, i parked,turn the car off, and then restarted it and the odometer settings cleared to 0 again. i got my windows back working on Auto by resetting. Anyone know whats going on?
Old 01-09-2018 | 11:03 AM
Bad battery, or loose/corroded battery terminal. Check them!
Old 01-09-2018 | 07:15 PM
climer55's Avatar
I believe you are exactly right my friend! I found that my terminals and cables had corrosion in them. I cleaned them real good and checked the voltage on battery. It’s showing 13 volts with the cables off and on. I believe it’s ok now. If not then I think your right on the battery. It’s a cheap battery and I’m not sure it is sized right. Thank you very much!
Ron A
11-02-2024 08:15 PM
NRS78
5G TLX Problems & Fixes
635
11-03-2021 10:03 AM
csmeance
1/2G MDX (2001-2013)
63
10-06-2018 06:13 PM
