Acura TL problem
Old Jan 9, 2018 | 08:57 AM
climer55's Avatar
Acura TL problem
this morning i started my 2008 Acuca TL as usual but i noticed that the Auto windows was not working and A & B odometer was on 0 as if it cleared everything out. Wehn i got to my destination, i parked,turn the car off, and then restarted it and the odometer settings cleared to 0 again. i got my windows back working on Auto by resetting. Anyone know whats going on?
Old Jan 9, 2018 | 10:03 AM
Bad battery, or loose/corroded battery terminal. Check them!
Old Jan 9, 2018 | 06:15 PM
climer55's Avatar
I believe you are exactly right my friend! I found that my terminals and cables had corrosion in them. I cleaned them real good and checked the voltage on battery. It’s showing 13 volts with the cables off and on. I believe it’s ok now. If not then I think your right on the battery. It’s a cheap battery and I’m not sure it is sized right. Thank you very much!
Ron A
May 5, 2026 07:11 AM
NRS78
5G TLX Problems & Fixes
635
Nov 3, 2021 09:03 AM
csmeance
1/2G MDX (2001-2013)
63
Oct 6, 2018 05:13 PM
