ABS Engaging Prematurely
I have an '05 TL AT.
When I press the brakes going over bumps, I can hear a clunking sound and feel the ABS brakes engaging. I take the same bumps with an '03 Maxima and an '04 Mazda 6 and an '06 MX5 and the issues are not there.
Any of you have the same problem?
I've started threads about this. IMO, the TL's ABS really holds it back performance wise. I've beaten the ABS by a substantial margin with it disabled. Once you add sticky tires you learn to never invoke ABS because once it starts it just goes crazy and you lose a lot of your braking. If you can keep it right at that point before it triggers it's a little better but still too conservative.
The worst is trail braking. I've had just the inside front want to lock and ABS reduced pressure to all 4 tires completely screwing up any hopes of getting a quick lap time.
I saw that thread you started IHC. It really sucks when you are just making a gradual turn at higher speed (55ish) and brake at the same time, the ABS kicks in and it feels like you are losing it. It's even worse when you need to make a sudden stop during a turn in the mid 20's. For some reason it happens more when you are going down hill or through a dip. I guess there is really not much you can do about it? What's the ABS recovering time?
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
joflewbyu2
10-08-2015 11:16 AM
