98k miles and havin some problems
1. Car seems to bog and or not be as responsive as it used to be.
2. Car idles sporadically, drops to 500 then to 900 then steady at 800 then repeat over a 5 minute period. (No not the fans or anything kicking in)
Im thinking at my mileage i should probably do the following:
New spark plugs, radiator fluid drain and fill, seafoam. Any other suggestions?
ScoobyZINE
My 05 is right at 95k miles.. Although I haven't experienced any of those problems, I did Seafoam it Saturday and HOLY SHIT. It was crazy. Sounds like it may have water in the gas since idles crazy, does it seem like it is sputtering and wanting to stall and does it stop when you increase the throttle?
There were times when it dropped to a little bit under 500 rpms but then bounced up again quickly as if the computer went oh fu- and reved it a little or something
Registered Member
Do you treat your car with a quality fuel system cleaner on a periodic basis - say every 10,000 miles? Have you had any check engine lights with codes indicating EGR problems? Does the engine hestitate and then pickup just as you tip into the throttle when leaving from a stop? Do you use high quality name brand fuel in your car?
Yes the car hesitates then picks up when leaving from a stop, no the car has never had a cel problem.
Even though you're not throwing a code (CEL) you might want to pull the EGR valve and check/clean/replace it. Seems to be a lot of problems lately with plugged EGR valves. Do a search for "P0404". I posted the scan for EGR removal in one of those threads. Blow it out with compressed air or just replace it.
Registered Member
Did you forget to reconnect a vac hose or something? Pop the hood and start looking for something obvious.
Noticed something new when taking out the spark plugs... The plugs are old but theyre white all around which my friend says indicates the engine is burning very hot which would mean its running lean. Which leads me to believe it is possible that my power loss issue im having in high temperatures is a combo of this and 90 degree air?
Either way im going to run some injector cleaner through the car
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
Mike Bertram
09-10-2015 09:27 AM
Zonian22
09-02-2015 08:19 AM
