6MT Synchros Replaced - 3rd Gear Problem is Back!
The synchros were replaced on my '06 6MT with 12k miles in Feb '08. Two years and 16k miles later, the problem is back.
I'm bringing it in tomorrow but I'm concerned about getting another synchro replacement. After another two years and IF the problem recurs, I'll be paying for the fix out of my pocket.
Those that have had the 3rd Gear TSB performed, has anyone else experienced the problem come back?
Received 2,599 Likes
20,000+ mostly city miles on the TSB so far its OK.
I did read about the GM Synchromesh when I first had the problem two years ago. However, I opted for the permanent fix.... at least I hoped replacing the synchros was the permanent fix. But it turned out it wasn't. I'll definitely consider the GM Synchromesh more seriously.
Middle Finger anyone?
Sooo...I'm confused. You did have the TSB performed? I ask because the TSB replaces the whole 3rd gear gearset and respective syncros. Not just the syncros. If you only replaced the syncros the first time then the problem is bound to return. You need the new gearset.
BTW I had the TSB done and the car shifts beautifully. 20k miles and still going.
i am so smart S M R T
i had the tsb preformed
about 1 month ago. The rest of my gears still kind of grind or are notchy. I am definlty thinking about getting the gm syncro shift fluid change during my next oil change. Is it just a drain and fill?
Registered Member
Yes, it's a drain and fill and it takes 2.3 U.S. quarts, which is 2 quarts 10 ounces rounded.
How bad is it? Is it not going into 3rd gear like before? Is it grinding like before? If so I say take that bitch back to where the TSB was performed and get them to redo it. OK. Find your original paperwork then go back and get them to redo it.
If it is THAT bad then they messed up the first time and it should be a mechanical fix. If it is kinda clunky but still goes into gear, then put in the GM stuff.
After my TSB was done I rode with the Honda Fluid for 1000 miles, to break everything in, then I changed to GM fluid. Never a problem since.
It kinda bugs me when people suggest the GM fluid to "fix" a transmission. It should be used as a preventative measure and not as a solution to syncros that have gone bad or a transmission that won't go into gear. To me it's the equivalent of someone saying their engine constantly runs low on oil and everyone tells him to just keep putting the oil back in. Or better oil. Whereas that person should check for leaks and fix the problem instead of avoiding it. Ok. My rant is over.
You wouldn't happen to have the paperwork still would you? It would be a page and a half of parts including a gearset.
I don't see any reason to do another tear-down...probably going to try the GM fluid next since the problem is not as severe as before the TSB was performed.
TSB not done by prior owner
So I made a few phone calls to the last dealer where the car was purchased by 1st owner. They told me the 3rd gear fix was not done and it would now cost me around 2 grand to get it fixed (67k miles at the moment). I am sometimes having a hard time engaging 2nd to 3rd gear. Will the GM fluid help? Can't spend 2Gs right now.
stealership
well i called my dealer to have some recalls done an asked if they could do a drain and fill on the tranny fluid. $50 if i supply my own fluid, but they said that if they put in any fluid that isnt honda fluid they will not cover any part of future transmission issues. I am out of warranty but i just had the 3rd gear tsb done. Should i change my fluid somewhere else so there is no record of it being changed to the gm fluid?
Forget about my question about the GM MTF-FM, got the answers at:
https://acurazine.com/forums/showthr...rd+gear&page=9
I have stopped getting stuff done at the dealer, got some basic done on my own and some done by a local fellow Aziner.
Was your TSB done before or after your warranty expired?
Now it's back to the original problem - occassional popping out of third gear, some resistance when shifting into 3rd coming from 2nd. The only difference is that this time, it seems to happen when the car is cold - during the first couple of miles of driving after the car has been sitting for a few hours. Before, it just pops out of third any time with no pattern.
Damn it to hell! The gear box is not broken it is the fluid! Change the fluid!!!!!!! There is no fix because it is not broken! Just get the gm fluid and stop talking about it!
From day one i noticed problems with third gear in my '06. Mentioned it to the dealer back when the car was new, and they claimed they "adjusted the linkage for me". I figured they were full of it as i noticed the problem driving off the lot, so that was the last time my car was at the dealer until i needed the power steering hose TSB done. I tend to shift pretty hard and throughout 96,000 miles had third either grind, felt like it was half way in, or refuse to enter only a handful of times, so it never really bothered me. My wife, on the other hand, who shifts with a much more gentle touch had a more consistant issue the few times she drove the car. I recently overhauled many of the consumable parts of the car and decided to give the GMSMFM fluid a try. As a joke, i told my wife that i took apart the tranny and "made some adjustments". She has since driven the car several times and is convinced that I am a mechanical guru, as the problem with third is now gone.
S2K folks sometimes buy it from:
http://www.hardtopguy.com/store/prod...0&bestseller=Y
I can't vouch for this vendor since I have not purchased it from them (yet). I am not affiliated with them either.
I tried to look for the paperwork the other night but couldn't find it. I remember seeing a gearset in the parts they replaced and I also remember that the part number listed in my paperwork was different than what was posted by someone here who had the TSB done. But the problem went away at that time.
NCTL05: Thanks for the follow up.
Here's an update. So I took my car to the dealership on 3/1/10 with two problems - 3rd Gear popping out and grinding noise when steering wheel fully turned coming from a full stop (coming out of parking lot). It sounded like the tire was rubbing. They ended up replacing the steering gearbox but that's another thread.
With the third gear problem, they were not able to recreate it - as expected. They had it for 5 days. I told them the conditions when it would occur - usually within the first mile of driving in the morning and within the first mile when coming home in the afternoon after the car's been sitting for a few hours. I went to pick it up first thing in the morning and test drove it with their tech hoping to recreate the problem. But even I wasn't successful. Then the tech told me that they replaced the trans fluid.
My car drives so much better than when I took it in. I've had it for a few days now yet still no issues. It seems that there is indeed a problem with the Honda trans fluid breaking down prematurely. I'll give it more time but for now, it seems like my problem is fixed.
I managed to get a reprint of the paperwork when they replaced the gearset two years ago.
Thanks for all the input.
Zonian22
11-14-2015 01:20 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
