6MT Shifter boot
Old Apr 14, 2009 | 07:46 PM
jsh139's Avatar
Question 6MT Shifter boot
Anyone know how this thing is held on?
Old Apr 14, 2009 | 07:50 PM
JwongTLS's Avatar
u see where the middle piece is?
push that part down 6' o clock. It should unhook and u should be able to slide it down
Old Apr 14, 2009 | 07:58 PM
jsh139's Avatar
Hmm.. I need to rephrase my question. I want to reconnect the shift boot to the shifter. It's just hanging there not held on by anything. Is there some sort of clip I'm missing?
Old Apr 14, 2009 | 08:27 PM
RC51Ryder's Avatar
Vroooom!!!
I know this one......A zip tie! Yeah, I was shocked when I saw it too. The boot is held to the silver ring by a small white zip tie on the inside, the silver ring is held to the knob with clips attached on the knob. When I changed knobs, I used super glue to bind the boot to the silver ring. It sounds ghetto but if done properly, only you will be able to tell the difference. I super glued the leather to the ring, used a zip tie on the outside to hold it together and made sure not to drive the car for a day or so to give the glue time to cure. After that, I cut the tie on the outside and drove away.
Take a look:
Old Apr 14, 2009 | 08:30 PM
RC51Ryder's Avatar
Vroooom!!!
Here is a pic of the bottom of the knob for reference.
Old Apr 14, 2009 | 08:39 PM
jsh139's Avatar
Ugh.. I had a feeling it was going to be something like that. So, you're saying that there's supposed to be a zip-tie on the inside of the boot? That's exactly what I was thinking of doing to fix the thing. I think I'd rather replace the zip tie than glue it.
So, of course my next question is how to remove the shifter surround to get to the backside of the shift boot? I tried lightly pulling on it, but I didn't want to break anything.
Thanks for the replies
Old Apr 14, 2009 | 08:59 PM
RC51Ryder's Avatar
Vroooom!!!
The leather folds the bottom of the silver ring and the zip tie is under it. To get to it, you will need to remove the center console and the entire boot from the shifter. That is why I went with the super glue option. It is kinda hard to explain but if you remove your knob, you will see exactly what I'm talking about.
Old Apr 14, 2009 | 09:22 PM
jsh139's Avatar
Yeah, that's what I figured. I'm horrible at gluing things, so I think I'm going to ziptie it. Now I'm off to find out how to remove the center console and pray I don't break anything in the process
Thanks again.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
MikeJM310
Sep 24, 2015 07:24 PM
