6 Speed tranny/clutch problem??????
Old Jan 4, 2012 | 06:28 PM
bluetl04's Avatar
hey fellas....so i have a 04 tl manual...Sunday i was coming back from Pa. I was doing about 80 or 85 in 6th gear...I then went and pushed the gas pedal to accelerate when i noticed my rpms went up and then back down...i tried to do it again but this time it didnt do it...so i pulled over and made sure all my gears were able to go in and out and it was fine...so i got back on the highway going through all gears and wot and it was fine.
So today coming back from work, it did it again in 6th gear.I then down shifted in to 5th and pressed the gas pedal and now the rpms went up in 5th gear
I did do the gm syncromesh about 10k miles ago..it is very cold here in CT...
Do you guys think the weather could have something to do with it or is my clutch starting to slipp?...i do have 140k on the car and origanal clutch...Maybe i should try changing the fluid again?...Let meknow what you guys think?...Thanks
Old Jan 4, 2012 | 06:31 PM
bluetl04's Avatar
And if you guys do think it is the clutch, does anyone on here thats from CT know of someone that will give me a good price to do the job?..thanks again
Old Jan 4, 2012 | 09:04 PM
Hi speed's Avatar
runnin a little boost
I think one of our vendors Excelerate performance is in VT. Look him up.
Old Jan 4, 2012 | 09:22 PM
SouthernBoy's Avatar
Registered Member
If your description is accurate, your clutch is slipping. How many miles on the car? Are you the original owner?
As you can see I have an '04 manual TL and will be turning 90,000 miles within the week. I expect to get at least another 100,000+ miles out of the factory OEM clutch, but will most likely not keep the car that long.
Oh, and the clutch assembly has nothing to do with the transmission. They are two completely separate entities so whether or not you used GMSFM fluid has nothing to do with the clutch.
Old Jan 5, 2012 | 10:48 AM
ez12a's Avatar
the overexplainer
ditto slipping clutch.
Old Jan 5, 2012 | 11:35 AM
mY sLOW UA6's Avatar
Slipping clutch I have to get mine done too, bluetl04 im from CT too do u remember me from ctvtec?
Old Jan 5, 2012 | 02:30 PM
bluetl04's Avatar
My slow ua6...I don't remember you... Where in ct you from?... How long have you been driving with a slipping clutch???... I need to figure out how long I can drive like this until I put some money together
Old Jan 5, 2012 | 04:31 PM
ez12a's Avatar
the overexplainer
if you cant do it as soon as possible, you need to drive very carefully and accelerate very slowly. The more you slip the clutch like that, the more you ruin your flywheel which in the end will cost you more $$
Old Jan 5, 2012 | 05:55 PM
bluetl04's Avatar
yeah i know...i am driving very carefully and letting the car get speed on its own..i am only driving my car to work and back for now...thank god my work is only 15-20 minutes and mostly highway...if i need to get around, i am using my girlfriends tl...i just wanna know the time frame before it actually completly goes
Old Jan 5, 2012 | 05:57 PM
bluetl04's Avatar
i just got a quote from the acura dealer and they want $2356.00 i think that is way to much but its a dealer..that price includes clutch kit, flywheel, labor and tax...what you guys think?
Old Jan 5, 2012 | 06:00 PM
ez12a's Avatar
the overexplainer
way too much. A clutch job should only be around 1.2k w/o flywheel. I dont think new flywheels are required every time unless abused.
Old Jan 6, 2012 | 03:29 PM
My clutch has been slipping since the car was purchased in October I have an extended warrenty so I ust need to find time to bring it in, I remember u sent sent me a link to your wheels when I was on ctvtec, u commented on my thread.
Old Jan 6, 2012 | 03:45 PM
94eg!'s Avatar
#1 Super Guy!
Talk to the dealer and get a price breakdown (labor & individual parts). The Acura clutch is made by LUK, and you can buy the EXACT same parts in a kit for ~$180 on ebay. Tell the dealer you want to provide the OEM parts or see if they will match that price (they won't). Now your only stuck with their cost of labor which now won't include any premiums they try to sneak in on parts (they always charge higher than MSRP). BTW: Also get a quote at the Honda dealer. This is the same clutch on the Accord V6 Coupe 6MT. Get a total quote first, and then have them break it down for you BEFORE talking about using your own parts.
LUK 08-047:
http://www.lukdepot.com/product/luk-...l-6-cyl-08-047
EBAY:
http://www.ebay.com/dsc/i.html?LH_Pr...&_sop=15&_sc=1
Old Jan 6, 2012 | 05:36 PM
ABP_04TL's Avatar
6-SPEED LOVER
Way to much i bought everything from acuraoemparts and paid 900 to my door
"flywheel
"pressure plate
"clutch disk
"pilot bearing....
Old Jan 6, 2012 | 05:52 PM
94eg!'s Avatar
#1 Super Guy!
"flywheel
"pressure plate
"clutch disk
"pilot bearing....
LUK makes the flywheel too.
DMF062:
http://www.lukdepot.com/product/luk-...l-6-cyl-dmf062
$301
http://www.carolinaclutch.com/ShowIt...0Flywheel.aspx
Old Jan 6, 2012 | 06:25 PM
bluetl04's Avatar
ABP 04TL...that is a real good price...how did you manage to get that price for everything?...did you have the dealer put it in or a private shop?...please get back to me...thanks bro
Old Jan 6, 2012 | 06:26 PM
bluetl04's Avatar
what is the honda part number for the clutch kit and flywheel?
Old Jan 6, 2012 | 07:35 PM
bluetl04's Avatar
so then LUK is what is inside a honda packaging?
Old Jan 6, 2012 | 07:36 PM
bluetl04's Avatar
http://www.carolinaclutch.com/ShowIt...0Flywheel.aspx.....
so then if i order the clutch kit and flywheel from this website, it would be the same as if i ordered from acura but just cheaper rite?....the total for both came out to $560 shipped
Old Jan 6, 2012 | 07:37 PM
bluetl04's Avatar
thats not a bad deal at all.....now i just gotta find someone to put it in for me
Old Jan 6, 2012 | 09:01 PM
94eg!'s Avatar
#1 Super Guy!
Yes. Pictures of peoples old worn-out clutches on this forum have shown it again and again. Exact same parts without the HONDA premium packaging. BTW: MSRP on that flywheel is almost $500 bucks now. If you DO need one, $300 is a great price (even with $39 shipping).
Or you could order them both separately (from the two links I provided) and save another $53 ($42 + $11 shipping). Kinda doesn't make sense not to.
You should probably go to the Honda dealer and ask. There are bunch of special tools required to install the self-adjusting pressure plate. The diaphragm needs to be compressed before you tighten the bolts or the mechanism can be permanently damaged (according to the Acura/Helm shop manual).
Old Jan 7, 2012 | 09:08 AM
bluetl04's Avatar
i am deff gonna jump on this...the dealer can go screw them selves...thank you very much guys for your help...
Old Jan 7, 2012 | 09:10 AM
94eg!'s Avatar
#1 Super Guy!
Good luck!
Old Jan 7, 2012 | 09:22 AM
KN_TL's Avatar
I've read this more than once. Rodney from J&R also mentioned it as he is selling a 6 puck disc and has experience with the install.
Old Jan 7, 2012 | 01:45 PM
ABP_04TL's Avatar
6-SPEED LOVER
I had it done by my friend, no issues at all... PM me if anythin
Old Jan 7, 2012 | 04:58 PM
94eg!'s Avatar
#1 Super Guy!
How on earth would you be able to tell if the self-adjusting mechanism was broken or not?
Old Jan 7, 2012 | 07:36 PM
bluetl04's Avatar
thanks guys...
KN TL.....i dont know who rodney is...is he someone on this forum?
ABP 04TL....does ur friend have a garage and where is he located?
Old Jan 7, 2012 | 08:43 PM
KN_TL's Avatar
Rodney Brown of jandrnextlevelperformance. He is a vendor here selling performance parts (turbo, clutches, ecu, etc).
Old Jan 7, 2012 | 10:09 PM
bluetl04's Avatar
okay...thanks man
Old Feb 10, 2012 | 10:11 AM
mc_holla's Avatar
@bluetl04
Did you order/install your clutch/flywheel combo as of yet? If so, what are your initial impressions? Had the clutch on my 04 go out on me yesterday and doing my due diligence.
All input would be helpful.
Mc
Old Feb 11, 2012 | 06:26 AM
bluetl04's Avatar
Originally Posted by mc_holla
@bluetl04
Mc
hey man, i bought the clutch kit and flywheel for $560 shipped and rite now, my car is at the acura dealer getting it put in. I dropped it off on Thursday and have not gotten it back yet. So as soon as i get it back, i will let you know how it feels
Old Feb 11, 2012 | 08:49 AM
mc_holla's Avatar
Aight Thanks.
$560! How did you manage that? and what did the dealer quote you for labor?
Old Feb 11, 2012 | 10:13 PM
bluetl04's Avatar
i went to a website called carolina clutches.com ....they have the luk clutch kit and the luk flywheel. Luk is the origanal maker of our parts but honda just stamps their name on things. the dealer is charging me $880 for labor. also included in that price is changing out the rear main seal
Old Feb 11, 2012 | 10:43 PM
riicky's Avatar
6MT
thats pretty good price for labor and i was gonna inform you to get the rear main seal changed as well but your one step ahead of the game!!
Old Feb 12, 2012 | 02:17 PM
bluetl04's Avatar
Yeah man, not that bad of a price. As for the rear main seal, the tech told me it would be a good idea to do it since everything was taking apart and he wouldnt charge me the lobor to do it, just the part. So, i think its good. They called me yesterday and told me it was ready but i wasnt around so i have to pick her up on monday. In the meantime, im enjoying the 2012 TL.
Old Feb 13, 2012 | 06:10 PM
mc_holla's Avatar
Here waiting for your initial impression @bluetl04. Ordered the parts (including a passenger side axle) and wanted to know what to expect when I get mine done later this week....
Old Feb 13, 2012 | 06:18 PM
bluetl04's Avatar
well, i just got home from picking up my car from the dealer. All i gotta say is, WOW!!!...what a difference. At first the clutch pedal felt hard but as i was driving and shifting, the pedal adjusted. My car deff pulls10x better and shifts really really nice
Old Feb 13, 2012 | 06:55 PM
ez12a's Avatar
the overexplainer
is the shifter less notchy feeling?
I have a TL with 66k miles (52k of those miles were not driven by me) and I cant really tell if my clutch is in the greatest of condition--it doesnt slip but just something that nags me is I dont know how hard the people before me drove it. I'm paranoid of it giving out any time but since it's a SAC i have no real way to tell..
Old Feb 13, 2012 | 07:14 PM
Chessie724's Avatar
In. Thanks OP for posting and thanks to those that contributed on the cost-saving parts info!
My clutch is not acting up at all, but at 86k miles (bought it with 53k), it's been in the back of my mind as just one of those nagging concerns. Not troubling, just back there waiting. I just hope there isn't a perfect-storm, double whammy thing with my 105k service and clutch at the same time. I'd like to have a half year or year of having the car paid off before getting hit with those big expenses.
Old Feb 13, 2012 | 07:44 PM
bluetl04's Avatar
You are welcome!!!...
