3rd gen. TL rubbing noise
My 08 TL-S has been making a rubbing noise when I make a sharp turn or U- turn. I brought it in to the dealership since it is still covered under my warranty and they said it was my rack and pinion. They replaced it and it happened again. So they replaced it and still there is no solution. I called AcuraCare and they said there is nothing more that they can do unless other people start to complain about it. So i am posting this out there and am asking you all to check the noise level if it you can hear it. If enough people complain to the dealership, they will make a recall for it. This is at least a $2K job.
Also, there has been a recent recall for the power steering hose. Apart toy it can get too hot and bust. Please forward to everyone you may know awho has a 3 rd gen. TL.
Sure it's not a suspension component or tire rubbing. Put the doughnut spare on one side and give it a try each way, then try the spare on the other side and turn each way. If still the sound, check the backing plates as they can contact the rotor on turns. A while back had a Maxima that needed the backing plate bent out slightly.
i had to bend the backing plate out on my car after i lowered it for some reason. i pulled out of the neighbirhood and heard a rubbing sound, knew it was metal, so i looking and seen a gash in the backing plate were the rotor rubbed it. guess it was from the toe being out, and the tie rod pushed against the plate when turning.
No problems since though. Good luck
MrHeeltoe
20
Feb 23, 2023 01:54 PM
