3rd Gen TL Reliability
Old Jan 4, 2026 | 03:17 PM
E_S.0's Avatar
Hi,
As of right now I have a 2nd gen TL-S (planning on doing the AV6 swap), and was wondering if an Automatic 3rd Gen TL-S has as many transmission problems like the 2nd gen does. If not, would any of you recommend it as a daily? And what does the maintenance/reliability look like all around?
Thank you
Old Jan 5, 2026 | 12:57 PM
SlippinNSlidin's Avatar
I'm pretty sure they fixed most of the transmission issues in the TL-S as it came out in 07-08 after they switched the transmission design up from the previous more flawed 04-06 transmissions. As for general maintenance they are a 18-19 year old car so some stuff will obviously be aging out but in general they seem pretty reliable at least on the major axes. The main things I have found to fall apart are suspension components (ball joints, lower bushing, struts, engine mounts) and sometimes some of the timing components will wear out (mainly the tensioner). They also like to develop an oil leak from the valvetrain gasket. One other thing to note is that these cars have a lot of electronic/luxury features and these seem to often be the things that break down over time. Nonessential things such as the mirror actuation, dimming mirrors, and the navigation unit/lightbulbs/memory seats/bluetooth will slowly degrade over time and will likely be nonfunctional in some capacity on any 3rd gen you buy.
Old Jan 5, 2026 | 01:18 PM
Get an 07/08 Base or Type S and you'll be set for a while
jkopuffs
Socal
Apr 20, 2013 11:07 PM
erick3
Feb 10, 2008 03:15 PM
big mike 13
Jan 16, 2008 09:36 AM
wackjum
Oct 23, 2007 02:20 PM
Crzy Acura
Jul 26, 2001 02:27 AM
