3rd Gen TL
Old Jul 17, 2018 | 05:52 PM
Cesar Salazar's Avatar
4th Gear
3rd Gen TL
Hi if I'm in the wrong thred please let me know. I just bought a 2006 Acura TL and everything is fine but when I get to 45+ miles on the turnpike it starts shaking. Can you please help me figure out whats wrong? Thank you in advance
Old Jul 17, 2018 | 05:54 PM
_Camus_'s Avatar
Couple questions:
1 - Is the steering shaking or the whole car?
2 - If you move to neutral while going at 45+ mph, still shakes?
Old Jul 17, 2018 | 06:00 PM
4th Gear
The steering shakes and the car shakes as well
Old Jul 17, 2018 | 06:05 PM
_Camus_'s Avatar
Check the state of your tires, last time my TL shook the rear left tire had a bubble. If the tires are ok and the steering still shake, check the balance of the tires, it must be way off to shake at 45 mph; Also check the bushings. I asked about going into neutral to discard any transmission axle issue.
Old Jul 17, 2018 | 07:36 PM
eaglegreen48's Avatar
2017 TLX TECH V6
Originally Posted by _camus_
check the state of your tires, last time my tl shook the rear left tire had a bubble. If the tires are ok and the steering still shake, check the balance of the tires, it must be way off to shake at 45 mph; also check the bushings. I asked about going into neutral to discard any transmission axle issue.
+1
Old Jul 17, 2018 | 07:45 PM
4th Gear
That's what I'm thinking. I don't know if it's one of the tires that was popped when I bought the car and they put air so I don't know if it has more air than the other 3. But I'm going to check the balance too this weekend when I get off work to make sure it's fine. Thank you alot for the advice.
Old Jul 18, 2018 | 06:52 AM
frankjnjr's Avatar
IMO: Sounds like a possible balance problem to me. Incorrect air pressure, won't normally create a "SHAKE, SHIMMY, or VIBRATION! Start, by having the wheels balanced, and go from there.
Old Jul 18, 2018 | 08:51 AM
Jackass's Avatar
1.) Does it have the factory wheels or aftermarket?
2.) Get the tires inspected and balanced.
3.) Have the rims checked to confirm they aren't bent
4.) Possible axle issues if the first three don't turn up anything.
Old Jul 18, 2018 | 11:38 AM
Shadow2056's Avatar
Cheapest solutions first:
-Jack the car up and turn the wheels. Look at the tread. Do any of the treads look....off? Like this: ====__====
-If so...replace tires. If not. Move to step two: Have the wheels balanced. If the wheels are off balance, have them replaced if wheel weights don't work(most likely a bend in the wheel).
Old Jul 18, 2018 | 09:45 PM
3gtltype-s's Avatar
Front turn signals
Picked up an 07 type s and having issues with front turn signals not blinking. Also having hyperflash on rear signals. No hyperflash during hazards but front still doesn't work. Parking lights work. Not running led's. Checked hazard relay and says (led) on front of box. Is that normal?
dbqtown
Apr 11, 2012 01:46 PM
04accordcpe
Oct 15, 2011 01:04 PM
StYLeZz101
Jun 30, 2007 06:21 PM
