3G TL Caliper Bracket Bolt...
Old Nov 30, 2014 | 07:44 PM
paulmnly's Avatar
Hello gents:
I have searched a bit and can't seem to find a clear answer or route. I seem to have lost the bolt that holds the Caliper bracket to the hub. It has a 17mm head. I have no idea where I can find another one, aside from going to the dealer...
Old Nov 30, 2014 | 07:54 PM
acrdr's Avatar
Dont even bother looking any other place then the dealer
They are inexpensive and not worth to go through all the trouble and try to match them
Old Nov 30, 2014 | 08:02 PM
nfnsquared's Avatar
^^^^ agreed.
And OP, you know there are 2 bolts per caliber, right? How do you lose a bolt that size?
FYI, the AT bolts are 12 x 1.25MM and the MT bolts are 14 x 1.5mm.
Old Dec 1, 2014 | 11:53 PM
BC2G's Avatar
Registered Big Dog
you need to check the caliper to see if the threading is stripped.
If the threading is stripped (which would allow a bolt to fall out - This happened to me)
see thread: https://acurazine.com/forums/problem...aliper-918996/
If you replace with OEM you will need to buy the entire brake caliper assembly which is like approx $150.
Or.
You can go to o'reilly / pep boys /etc and buy an aftermarket remanufactured brake caliper bracket for approx $20 ....I did this and all good so far.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
polish_pat
Sep 30, 2015 12:22 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
