3G TL Caliper Bracket Bolt...
Hello gents:
I have searched a bit and can't seem to find a clear answer or route. I seem to have lost the bolt that holds the Caliper bracket to the hub. It has a 17mm head. I have no idea where I can find another one, aside from going to the dealer...
^^^^ agreed.
And OP, you know there are 2 bolts per caliber, right? How do you lose a bolt that size?
FYI, the AT bolts are 12 x 1.25MM and the MT bolts are 14 x 1.5mm.
Registered Big Dog
you need to check the caliper to see if the threading is stripped.
If the threading is stripped (which would allow a bolt to fall out - This happened to me)
see thread: https://acurazine.com/forums/problem...aliper-918996/
If you replace with OEM you will need to buy the entire brake caliper assembly which is like approx $150.
Or.
You can go to o'reilly / pep boys /etc and buy an aftermarket remanufactured brake caliper bracket for approx $20 ....I did this and all good so far.
Or.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
