2008 TL 180k miles
2008 TL 180k miles
Yesterday I changed the tensioner which was making a grinding noise...good as new
but now I can hear a valve tap
is it worth having acura adjust them?
is it involved?
labor time?
thanks
all maintenance done....transmission drained and filled and timing belt done 25k miles ago
is it involved?
labor time?
thanks
the Valve adjustment is around $600 depend on your location.
don't worry about it just change the oil according to the MID and you are good. The tap you heard might not be the valve given the previous owner had it done. what you hear might be the injector noise.
this is what it sounds like I found a video on youtube...mines much more faint not as bad...
I know its not timing belt or tensioner because it was done 20k miles ago
gotta be valves
gotta be valves
in both case of the video its the tensioner, if you refer to the tick tick sound that actually is the injector. Valve adjustment help but not by that much, I owned four Honda/Acura and non of them ever get valve adjusted and yet no strange noise but again all the previous owner follow the dealer scheduled for oil change.
yea its like a tick tick and a tapping, louder then it should be that is for sure, if its injectors, ill install injectors
timing belt tensioner has 20k on it
I told you so, if you think this is loud wait until you heard the direct injected car now these days.
nope injector will sound the same even you replace with a new one.
Yep, classic injector noise. Normal.
mada51589
05-03-2022 08:54 PM
