2008 Acura TL
Old 09-07-2015, 10:29 PM
bryan zaragoza's Avatar
2008 Acura TL
have a 2008 acura tl and i was driving it at 35mph and out of no where the VSA came on and my car lost all power . i had to come to a complete stop and shut the car off. when turning back on irealized the check engine light was on i pushed on and off the VSA multiple times. Then the car was good to go after a few minutes. i let it sit all day and i just took it for a spin the check engine is still on but car is running fine. any suggestions as to why that happened or why the check engine light is on?
Old 09-08-2015, 12:11 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
I suggest you hook up an OBD2 scanner and see what code you threw and start working backwards from there. Either buy a scanner, find someone who has one or hit up a shop and ask them to scan it.
Old 09-08-2015, 12:12 AM
TacoBello's Avatar
The check engine light will likely stay on until it is cleared with an OBD2 scanner.
Old 09-08-2015, 12:28 AM
Received 8,691 Likes on 6,705 Posts
2008 acura tl
Check your battery terminals and all the grounds and make sure they're clear of corrosion and tight
fuct
05-14-2017 09:43 PM
Shaqs2002TLS
1/2G MDX (2001-2013)
09-20-2015 05:23 PM
HeloDown
09-08-2015 06:51 PM
darksky
09-05-2015 03:11 AM
heyitsvic
09-04-2015 09:38 AM
Quick Reply: 2008 Acura TL
