2007 Acura TL engine hiccups on stops with noise
Old May 19, 2018 | 12:49 AM
Acuratl help's Avatar
The engine sounds and runs very ruff. I have no clue what’s happening,
Old May 19, 2018 | 08:09 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a topic/technical issue which will require replies, and not a "New Member Introduction", this thread has been moved to the model specific forum.
Old May 19, 2018 | 02:02 PM
vpasla1's Avatar
It's hard to tell with such a vague description. How ruff is it?
Did you try looking under the hood?
Old May 19, 2018 | 05:06 PM
sparc's Avatar
What maintenance have you done on the vehicle since you've owned it. Has everything been checked and serviced per Honda/Acura? Fluids? Filters?
You may also want to consider taking it to a good independent mechanic. Then report back on what he finds. Whether it's check engine light codes, etc.
That would really give us enough information to help you further. Especially if you don't know anything about the service history of the vehicle.
Old Jun 28, 2018 | 01:23 AM
Hyperblu's Avatar
Mine has done this before as well when it was low on oil. It now does it with full oil level now. I'm beginning to think its timing related. Either the belt is too stretched or the plugs are causing detonation. It usually happens under a short burst of throttle from a dead stop, correct?
Old Jun 30, 2018 | 06:43 AM
quantum7's Avatar
You need to check for codes....connect OBD II and see what comes up.
SergeyR1
1G TSX Problems & Fixes
Nov 4, 2009 01:33 PM
kennelm
Feb 1, 2006 07:30 PM
03CoupeV6
Nov 14, 2005 09:48 PM
