2007 Acura Tl crank no start
I have this 2007 Acura Tl I have recently purchased off Facebook marketplace I drove 3 hours to get this car and it had overheating issues and smoke coming from the exhaust and I drove it back home 3 hours back with a misfire it drove home perfectly fine had to stop once in a while to put coolant in it but other than that it drove fine so when I got home I changed the spark plugs and it resolved the misfire it started it up nice and ran good but then one day I was on my way to go get head gaskets and came back to it stalling on me and didn’t want to turn on ,I got it to turn on once and moved it to a different spot on my driveway and stalled again so then I went and changed the head gasket and coolant manifold and thermostat gaskets and then put everything together and made sure it was timed perfectly and I went and go head and start to figure out why it was cranking and but no start serval mechanic told me to change crankshaft sensor so I did ,and also they told me to change camshaft sensor and I went and go head and did but still cranks no start,every time I crank it cranks but like stutters like if it would want to start ,also smell gas when I keep cranking it ,tried starting fluid still nothing,if anybody could help me that would be nice.
check the injectors make sure they are spraying properly; same with fuel pressure make sure it's good you may have a bad pump. Also are you getting spark? Did you do a valve adjustment? Have you tried starting in Neutral?
Noah k
10-29-2021 02:56 AM
Limitless
08-07-2020 07:26 PM
