I own a 2006 TL Base, Lately my car would have trouble starting in the sense where I would have to turn the key back and fourth on the steering column multiple time "usually 3 to 4 times" and then it would start. Battery was replaced about three months ago and test and powers up fine. When having this issue that starter would never click like it was attempting to start or lagging. All of the lights come on in the vehicle and dashboard and when it finally decided to start after the forth or fifth turn it would start right up with no straining on the starter. Well now well this lasted for about 30 days and now the car refuses to start at all. After some research I've heard the IGNITION SWITCH/ OR STEERING SWITCH could be the issue. I doesn't lead to me to believe its the starter due to it not having any issue with it clicking or straining in the past or present. PLEASE ANYONE WITH EXPERIENCE WITH THIS GIVE ME SOME INSIGHT
Honestly, I think it's your starter that died. It's cheap enough to replace and not a bad idea to do on an 11 year old car, even if that isn't the issue.
mine is on its way out. Started acting up really bad just a few days ago. I intend on replacing it this weekend. I have a 2006 TL also, with 149xxx km (roughly 90k miles, I believe).
If you can, try to get your battery tested. I does sound like the starter is going out. But a battery test is free ( even though the auto part stores sometimes fail the test when the battery is fine)
I am not sure if this is possible because I have not seen where the starter are on these cars but try whacking your starter with a metal tool or something then see if it'll crank.
other than that I agree with taco it wouldn't hurt to replace a starter on a car that age.
You shouldn't just replace the starter because you think it's the issue. Diagnose it and make sure the starter is receiving power. All you need is a multimeter for that. Check the actual connection at the starter as it is known to come loose on some J series.
This is the correct answer for sure....
Everyone is right that it could be your starter...or your ignition switch...or a few other items. Process of elimination with the items you can actually test until you get down to the more complicated items to test and/or replace.
