2005 tl won't start
2005 tl won't start
Hi I need any help I can get I have a Acura TL 2005 I put a new starter in it still had problems starting it it takes anywhere from 5 to 30 or 40 times before starting so I replied the starter relay didn't fix it what else can I do or look at to find the issue I can't afford to take it in any help on what could be wrong would be appreciated thanks
IT dose start after trying a bunch of times and it runs fine after it finally starts I replaced the starter and that wasn't the problem so I replaced the starter relay still no difference I also bought a new battery thank you
dose not start and die it finally starts as it normally would but it's taking more n more tries to get it to start I hope that explains it better I'm sorry I wish I could explain it better and appreciate your response
Most likely ignition switch. I recommend getting OEM switch since aftermarket parts usually are pretty low quality and fail quickly. I believe that is the correct part:
https://www.oemacuraparts.com/oem-parts/acura-switch-steering-35130saaj51?c=Zz1lbGVjdHJpY2FsLWV4aGF1c3QtaGVhdGVy LWZ1ZWwmcz1jb21iaW5hdGlvbi1zd2l0Y2gmbD00Jm49U2Vhcm NoIFJlc3VsdHMmYT1hY3VyYSZvPXRsJnk9MjAwNSZ0PWJhc2Um ZT0zLTJsLXY2LWdhcw%3D%3D
or part number
Should be easy to replace. Get the covers around steering wheel off and you are almost there. I can post some pages from service manual, or look at the youtube how people do it.
I didn't watch the whole thing but that should about cover it:
or part number
35130-SAA-J51
