2005 TL Malfunction Indicator Lamp
My 2005 TL MIL is blinking and its not the gas cap!! Its running rough, feels sluggish, when i accelrate from low rpms and the exhaust smells rich. Does anyone know what could possibly be wrong? I would greatly appreciate any help. Thanks!
Registered but harmless
Received 1,149 Likes
I don't recall if the codes will stay for several ignition cycles unless you have a reset tool.
You should be listening for a change in the idle as each coil is disconnected.
A change in the idle = good coil.
No change in the idle = bad coil, which must be replaced.
After researching the symptoms (sluggish idle, exhaust smells rich) I determined that it might be the 02 sensor. I replaced that, reset the codes and it still ran sluggish. However instead of 0300-0306, i only registered one code which was 0305. So i switched out four and five coils then reset the codes. Got a code back showing misfiring on P0304. I bought a new coil and booyah!!! Problem solved! Thank You. I wonder how much the dealer would of charged me for all of that!
The codes aren't going to go away until you replace the bad coil(s).
A SiQ TL (04-01-2012)
you may want to keep the 02 sensor you replaced and save it for later as it did not need to be replaced.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
Eggs999bacon
09-24-2015 10:08 AM
