2005 TL automatic whining when accelerating
Old Nov 19, 2014 | 07:59 PM
patrizio2005TL's Avatar
5th Gear
Hey Everyone,
Need some help. I'm an Assistant Service Manager at a Lexus dealer in Montreal. We got a 2005 TL with 144,000 kilometres (100,000 miles) as a trade in and I jumped on it. Clean, all maintenance done at Acura dealer, no major issues at all. Only thing I'm getting a whining noise when accelerating, mainly 1st and 2nd gear. Some of the mechanics I work with say its a tranny issue, others say it isn't. Gears change smooth, no delay or slipping. When I put it in neutral noise is gone. Noise is there as soon as I barely touch the pedal. Parts manager buddy of mine at Acura says may be the tranny, but I'm not too sure. Anyone else had this issue?
Old Nov 19, 2014 | 11:32 PM
YeuEmMaiMai's Avatar
check your front wheel bearings
Old Nov 19, 2014 | 11:55 PM
Ndanny's Avatar
I have that issue too with my 03 TL. I have checked the bearing and it seems to be OK. Any other recommendations?
Old Nov 20, 2014 | 05:01 AM
I had the whine and it turned out to be driver's side bearing took a crap. replaced it and no more whine. There is a TSB that indicates some differential noise is normal on these newer transmissions.
hopefully it is not a torque converter coming apart as that means new transmission
Old Nov 23, 2014 | 06:37 AM
EddieOnAZ's Avatar
Originally Posted by patrizio2005TL
Hey Everyone,
Hey man! I'm in Montreal too and my tranny definitely whines too. If you want to check mine out maybe we can compare both and see if it's the same kind of noise. I'm almost 100% sure it's my tranny doing that noise.
Old Nov 24, 2014 | 06:05 PM
5th Gear
You think it can lead to tranny failure?
EddieOnAZ's Avatar
Hey OP, you sent me a PM but I can't reply, apparently your inbox is full. Delete some messages or message me your phone number. I'll be glad to help.
Old Nov 24, 2014 | 06:06 PM
5th Gear
Im worried my tranny will go. Im gonna install a tranny cooler i bought maybe will help?
Old Nov 24, 2014 | 06:09 PM
EddieOnAZ's Avatar
I'd have to hear it in person. I know a friend of mine compares it to a spaceship sound haha.
If your car is like mine then there's nothing to worry about.
Old Nov 24, 2014 | 06:11 PM
5th Gear
Exactly...hopefully it wont lead to failure
Old Nov 24, 2014 | 06:20 PM
EddieOnAZ's Avatar
It shouldn't. If you are worried, look into the 3rd and 4th transmission pressure switches. Apparently the failures we see on our trannies are related to those, I don't think heat is the biggest factor. It's not costly and you can even DIY replacing the switches, good preventive maintenance.
Old Nov 24, 2014 | 06:49 PM
5th Gear
Have you done it? And have you donr the tsb on the ps inlet o ring?
Old Nov 24, 2014 | 07:00 PM
EddieOnAZ's Avatar
I haven't done the pressure switches. I DIY'ed the PS o-ring, go to luciani Acura on jean-talon near Decarie. They have the o-ring in stock at all times if I recall correctly. Plus Steve (the parts guy) is a pretty knowledgeable guy when it comes to those cars.
Old Nov 24, 2014 | 07:03 PM
EddieOnAZ's Avatar
The o-ring replacement takes about 5-15 minutes to do, pretty simple DIY. Only thing is you have to make sure you get the old one out and it tends to stay inside when you take the hose out. I could explain it better to you in person cuz my memory is a bit fuzzy.
Mike734
Dec 10, 2021 01:25 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
lanechanger
Oct 13, 2015 10:56 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Joe Avesyan
Sep 29, 2015 03:57 PM
