2004 TL A/T pulls at low and high speeds
Old Mar 3, 2019 | 02:33 PM
spotpea's Avatar
Hi,
I purchased a used Acura TL in November with 126,000 miles on it. Well serviced but noticed it has an odd pull in the front wheels. It happens when slowing to a stop - the only way I can think to describe it is it feels like if you catch an edge when skiing. The car just pulls in one direction and fights the wheel. At high speeds, when you take long arcing curves like a highway ramp there is a softness and a slight need to correct as well. I was just ordering tires as I assumed they are just old and the sidewalls are worn, but thought I’d ask here too since it might be something more sinister.
thank you for any thoughts you may have!
Old Mar 3, 2019 | 03:02 PM
could be dragging brake calipers
Old Mar 3, 2019 | 03:19 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Get the front end in the air and spin the tires by hand. See if they rotate freely or if you hear any rubbing.
Old Mar 3, 2019 | 04:31 PM
Skant's Avatar
Inspect tires , pressure, balance rotate in x pattern
.for start ..then go deeper if needed and get under to do all point inspection..
Old Mar 3, 2019 | 04:46 PM
Midnight Mystery's Avatar
Null and proud of it
Mine had a slight left pull... Corrected temporarily by slightly over inflating right front tire...
I too had the hard left pull under moderate/heavy braking... 2008 TL base at 105K...
03tlswfl
Feb 12, 2019 06:09 AM
FF06acuratl
Dec 9, 2018 02:45 PM
alecstg
Jan 14, 2015 11:26 AM
inkonspikuos
Feb 1, 2008 03:41 PM
