2004 TL Headlight Moisture
Old Feb 25, 2010 | 11:08 AM
Polynomial's Avatar
I have a moisture problem for the headlight on the driver side of the vehicle. What might be the best solution to this issue?
Thanks in advance!
Old Feb 25, 2010 | 10:36 PM
csmeance's Avatar
have you tried changing any of the bulbs in the past few months? Did you wash it with cold water on a hot day or vice versa? Have you gotten into an accident or gotten a large chip on the lense of the headlight?
Old Feb 28, 2010 | 02:24 PM
BlackMan29's Avatar
5th Gear
I have the same issue on my 2004 & 2005 TL. Can I use a heat gun to clear it up ?
Old Feb 28, 2010 | 02:25 PM
TheDanger's Avatar
2007 TL
You may need to take the lens off and reseal it. Check the seals on the back.
Old Feb 28, 2010 | 10:43 PM
Radcliffe1's Avatar
From the Desert 2 the sea
Got the same issue on my 04. Never done anything to the housing. Guess I'll need to check and make sure bulb and harness are snug.
hashbrown
Feb 18, 2022 11:20 AM
Mr.Tea
Oct 2, 2015 10:32 PM
MilanoRedDashR
Sep 27, 2015 10:15 PM
h22lude
Sep 27, 2015 06:22 PM
AmplifiedDetails
Sep 24, 2015 02:55 PM
