2004 Acura tl transmission fill plug
Does anybody know where the fill plug is on a 2004 acura tl. I've watched a few videos and they are not quite clear on where it is. I think I have located. But it looks like there is a line running on the top of it that may have to be Unbolted and moved over to access it. Also is it necessary to replace the filter as well when doing the 3x3 drain and fill?
That's the oiljet line, you can remove the bolt holding it down and lift it up.
I just fill my transmission using the dip stick hole.
Ignore my post above. It seems some 2004 TL have a fitting on top of the fill hole.
https://acurazine.com/forums/third-g...l-hole-887151/
Don't pull on it by the hose or you'll be sorry.
Rotary4life
1G CL Problems & Fixes
02-03-2009 12:03 PM
