2004 Acura TL
Old Jul 28, 2017 | 01:44 PM
nweaver0525's Avatar
2004 Acura TL
Hi I was told by a mechanic that my front lower control arms needed to be replaced. However when looking online all I can find is ones marked for rear suspension. Am I searching wrong? I feel like an idiot, I can usually understand enough to get the right parts and my husband puts them on. Is there any way I misunderstood the guy? And it would actually be the rear?
Old Jul 28, 2017 | 02:17 PM
flyromeo3's Avatar
What needs to be replaced are the bushings. There are 3 of them in total.
Youre mechanic should be able to get you oem bushings which he can then press them into your current lower control arm. It's definitely a lot cheaper than buying a whole new arm.
Unless he saw the control arm cracked.
Old Jul 28, 2017 | 03:49 PM
NZKIWIS's Avatar
5th Gear
Try this site... may help you for what you are looking for https://oem.heeltoeauto.com/auto-par...lower-arm-scat
The 3 bushings as "flyromeo3" stated are part numbers #9 ,#10 and #11 as per diagram..... your mechanic should be able to press them out...good luck!
Old Jul 30, 2017 | 01:33 PM
Glorygang600's Avatar
If you care about your husband buy a new arm instead of just a bushing I did the later on mine once whatta bitch that was
Old Jul 30, 2017 | 04:12 PM
NZKIWIS's Avatar
5th Gear
It may also pay to get a wheel alignment done after you have replaced the control arm bushings or complete lower arms.
Ron A
May 5, 2026 07:11 AM
csmeance
1/2G MDX (2001-2013)
63
Oct 6, 2018 05:13 PM
vpasla1
Nov 6, 2016 02:30 PM
dallison
Jan 28, 2015 07:38 PM
rets
Jan 1, 2013 09:50 PM
