2004 Acura 3.2TL won't start
9th Gear
Does anyone know what EXACTLY I would need to replace for the 105K mile service? I am at 110K. I turned it of last Tuesday and didn't use it on Wednesday. Thursday afternoon i went to turn it on and it sort of turned on but within seconds it turned off. Now it won't turn on at all. When i tried to turn it on again it made a noise. Sort of when the car is already on and you think its off and you "try" to turn it on again, that noise it makes, well it's making that noise. I've had two people tell me it might be the timing belt BUT they are not positive. So i would like to do the whole service and take it from there.
Any input would be appreciated!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
It's hard to know based on that paragraph, but I really doubt it's the TB. Probably a bad starter, bad starter solenoid or bad/low battery.
If clicking, your battery is dead.
If grinding, probably your starter teeth are ground down and can't turn the engine.
If no noise, starter failure
If the car tries to start again but can't, then you have an issue with either fuel or the spark plugs.
Thanks!!
Thanks!!
You know this noise by experience? More than likely your starter or battery. Get both checked out. Timing belt would be on the bottom of the list for reasonable culprits.
9th Gear
I got the car started. I changed the spark plugs but it wouldn't turn on. I had to leave the gas pedal all the way down while turning the engine. that was this morning. Turns on normal now.
Pushing in the gas pedal doesn't do anything on the TL. The TL doesn't have a carburetor, it's FI.
Like Majofo said..unless the something wrong with the throttle body where it doesn't open at all...relay, app etc
Aside from that...your symptoms could be indicating the starter solenoid going bad..
Sometimes it won't completely go all at once...If that's the case, you will experience what you already did, again.
Included with your description, you should note whether the engine turns/cranks normally when it does, so we can determine whether it's your battery. How do the cluster lights behave when you turn the key, do they flicker, or just dim? It could be an simple oxidation terminals on the battery, oxidized ground.
"car doesn't start" could have a lot of reasons behind it.
Clicking sound when you turn the key could be the solenoid.
Not too long ago, my friend's car experienced this...sometimes it would start, sometimes it wouldn't. It would either start, or click. It turned out the solenoid was going bad, until one day, it stopped altogether and it would only click.
hey guys, i had the same problem for a while where after a few tries then the car would turn over and start. but today it never started, so I'm guessing its gone for good now. if the solenoid is bad do i buy a new starter or is the solenoid something separate. i have to take the car to the dealer, but i figure its best for me to buy the starter online and then just have the dealer replace because i know for sure they will rape me for a new starter. so should i go a head and buy a new starter?
saberlove
03-11-2021 09:29 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
