A-130: DIY to fix "Tighten Fuel Cap" message
Yes, get the Denso (OE, look for "Japan" next to "Denso"), not the less expensive Chinese-made knock-offs (Dorman, Std Motor, Wells, etc.). Installed mine in May 2017 and haven't had any probs since.
US$126.00 on Amazon
Or ~$86 (for refurbished?) on eBay
https://www.ebay.com/itm/197000314847
I'd go with the first one on Amazon, just to be safe.
US$126.00 on Amazon
Bought a $17 replacement from Amazon
that and installed it yesterday. When it arrived it looked almost identical to the first one, except for having the Acura part number 36162-RDV-J01 stenciled on it. Will see how long this one lasts. Hopefully it doesn't fail for a while so I can avoid spending $186 for the part from Acura.
Bought a $17 replacement from Amazon https://www.amazon.com/dp/B09MKRCYK9...d_asin_title_1 that and installed it yesterday. When it arrived it looked almost identical to the first one, except for having the Acura part number 36162-RDV-J01 stenciled on it. Will see how long this one lasts. Hopefully it doesn't fail for a while so I can avoid spending $186 for the part from Acura.
Been putting this off for a decade now
Took my old one off again for cleaning to see if that would help but still getting intermittent (and more often now that it is warmer/summer) Prices for the OEM part from Acura direclty seem to have jumped up to 190 bucks..https://www.acurapartswarehouse.com/...oid_valve.html
Interestingly enough, found a reddit post that seems to claim the Odyssey's part number seems to work without issues: https://www.reddit.com/r/Acura/comme...r_36162rdvj01/
I'm inclined to give it a shot at half the price.. Will reach out to my honda parts guy and report back shortly..
Took my old one off again for cleaning to see if that would help but still getting intermittent (and more often now that it is warmer/summer) Prices for the OEM part from Acura direclty seem to have jumped up to 190 bucks..https://www.acurapartswarehouse.com/...oid_valve.htmlInterestingly enough, found a reddit post that seems to claim the Odyssey's part number seems to work without issues: https://www.reddit.com/r/Acura/comme...r_36162rdvj01/
Even though the 'root' RJA is different than your 3G TL 36162-RDV-J01, it' compatible with the V6 the Odyssey is running.
Decoding Honda and Acura part numbers - Ultra Racing USA, LLC - Chassis Tuning Specialist Since 2001
"A" means that the part is for the North American market. Japan spec parts would carry a "J".
2004-2008 Acura Purge Control Valve 36162-RDV-J01 | OEM Parts Online
This is the 04-07 Honda Accord Part: 36162-RDV-J01 - It states it fits 05 Accord Hybrid for $180.54 - Same part # as 04-08 Acura TL.
36162-RDV-J01 - 2004-2007 Honda Accord - Valve Purge Control Solenoid | Genuine Honda Parts
On site it states it fits 05 Accord Hybrid for $83.21 Part #: 36162-RJA-A01.
36162-RJA-A01 - Genuine Honda Valve, Purge Control Solenoid
If you follow this sequence, then the Part #: 36162-RJA-A01 should work for 04-08 Acura TL
Crestwood1001
Jul 10, 2014 04:52 PM
