12V Power Port not working in front of Shifter
05 TL W/Navi......My 12v Power Port that's inside the tiny door in front of the shifter is not working. I checked fuses and replaced #9 fuse but still not working, what else could it be?
CallMeMONGOOSE (04-12-2023)
04-06 TL 12V Accessory Port Not Working
I've been trying to figure this out also, mine is a 2006 TL manual trans, and the 12v port stops working when the car warms up. But when I leave the car off sitting for more than 10 minutes and start it again, it comes back on. I've replaced fuses twice. How do I fix this?
Had the issue with disappearing voltage while car got warmer. Identified shortcut - however the wire was not totally cut but burnt 🔥 In result it was conducting when go hot.
Check the connections first and any hard bends on wire.
CallMeMONGOOSE (04-13-2023)
Solution
So I need to find the actual wire for the 12 volt port and check to see if its damaged, then get it replaced and keep it from getting damaged again?
fishacura
08-15-2016 03:32 PM
