'08 TL Type S engine problem
So carried the car to the mechanic to find out i have 70% leakdown on my 4th cylinder. He says probably cracked, broke piston or piston rings. He also checked to make sure car wasnt over rev and no dents in piston nor bent or floated valves.
Question is whats the correct way about going with this.... another used motor or 4k in fixing it??
Used motor with good compression numbers + timing belt & water pump, etc. I think the J35A8 can also be found in various model years of the RL.
The 4th cylinder is the most susceptible to running lean because it is at the end of the returnless fuel system. A bad batch of gas and some high rpm runs could have made it detonate or go dangerously lean if there was fuel system issue.
Did you check the spark plug? I've heard of the #4 plug backing itself out.
Uh, so what is the original symptom, why did you bring it to the mechanic? Misfires, uneven idle? Unless he as a scope, he can't see if the valves made contact with the pistons and even then it's hard to see. 6mt or 5at?
The leakdown is done through the sparkplug hole so that eliminates the sparkplug. The mechanic can do a more thorough investigation before pulling the heads. Squirt oil in the cylinder and retest. If it gets better it's rings. If not it's valves. If it's a valve, pull the intake off and listen if you can hear the hissing on the inlet side or pull the exhaust back from the head and see if you can hear hissing from the exhaust side.
It can even be a headgasket. Any loss of coolant, any funny smells from the exhaust, any water in the oil?
Most importantly, how many miles are on it and has it ever had a valve adjustment?
he did the dry test and wet test. He said after that he did the leak down and could hear the air coming through the oil fill cap
This car is 6mt and i still do not know what could have caused this. He stuck a camera inside the head and no piston to valve contact was made.
You will always hear some air getting past the rings. It depends on how much was getting past the rings.
You can't always see piston to valve contact even with the heads off, much less with a camera in the spark plug hole.
So, what are the original symptoms, why did you bring the car to the mechanic in the first place?
I'd pull the head and check the valves before making a decision. The used TL-S engines aren't cheap, $3-$4,000, so you might want to look into a new Acura block assembly:
Part# 10002-RDB-A00 List $3027 Net $2270.
Looks complete even with an oil pan, so do the heads, slap them onto the new engine and you'll be good to go and know what you have, rather than the used route.
Just curous, how many miles on the car.
me personally never over revd the car but i brought the car in for a SLIGHT hesitation. Acura did some test and said the EGR valve needed to be replaced. Called me and said the car was finished. I then got in the car and noticed the car was still idling funny but i drove through the parking lot to exit the lot. Right as i was about to exit the check engine came on... i then just backed right back up and pulled back to the service bay. That is when they said the car had been over revd ??????
To tell you the truth, 70% leakdown for a bent valve is not that bad. It's easy to get 100% leakdown and the valve will still look good to the eye.
Now you have to choose to have the heads rebuilt or to install used heads. It's too bad you don't have someone that can do it for you, it's going to be expensive but it's 80% labor.
Well i am very mechanically inclined when it comes to things like this. Would it be best to just take the initial head off that is having the problem and have a machine shop look at it??
BTW I HATE CARS i really appreciate your input as i have read many articles from you and mostly in the Turbo Thread.
or you can go the used route.
depending on which one is cheaper!
he was installing it, but got the timing wrong and bent some more shit.
instead of doing it wrong again, he got his mechanic to install used heads.
here's the thread: https://acurazine.com/forums/showthread.php?p=13468849
so the decision is yours.
I'd redo the heads. Used 3.5 heads for the TLS are not common, especially the front head, and will run $8-$1000 for the set. But you've got to make certain there is no problems with the bottom end or all the work will be for naught.
There's nothing that can happen to the bottom end to give a misfire across all cylinders short of it being run out of oil. Surely it's possible but there would be noises associated with running out of oil and damage bad enough to cause a major loss of compression.
You can always pull the catalytic converters off the head or even back a little since you have to do that anyway and stick some compressed air in the spark plug hole to confirm the air comes out of the exhaust side (with the exhaust valves on that cylinder closed). You'll always hear some air getting past the rings in the crank case (through the oil fill hole) but there should never be any air getting past the valves.
You can have the heads rebuilt (seats, exhaust valves, guides, and seals) usually for a reasonable price. If you pull the heads off yourself, you should be under $1k for the whole job including the labor to rebuild the heads. You can see how much the shop will knock off if you disassemble the heads yourself but it's not a novice job and you'll likely have to buy a valve spring compressor.
I don't want to be insulting but it can't hurt to check valve lash before you pull the heads. It's extremely unlikely and nearly impossible but if the valves were too tight it would cause the same problems. At 60k I would say there's a .1% chance. You never know if the previous owner tried to adjust his own valves for some reason and set them too tight.
Well im hoping its just the head also but i want to also say that Acura has already under warranty replaced this head. I am not sure if they correctly reinstalled this new head or not?? Once Acura saw the overrev code that came up while i was in the parking lot th they said they would not touch the car. I am pulling more towards a mechanic was hot roding my car on test drive and that is when the code pulled.
I am the very first owner of this car btw
Wait. What?!?!?
You have never over-revved the car. After taking to the shop, it now has an over-rev condition?
I'm no math genius, but even I know 1 + 1 = 2.
Why aren't you pushing the dealer/mechanic to prove (via ECU logging) the over-rev condition?
Does anyone if a date/time code is logged with the over-rev? Is the over-rev in fact logged in the ECU or is that just rumor?
Wait. What?!?!?
I REALLY DO BELIEVE IT STORES THE DATE AND TIME.
a
If there is an over rev the ECU stores the RPM and I think the date that it happened. It's a good diagnostic tool and it's a good tattle tale for warranty purposes.
Thanks and sorry for the bold format, copy/paste thing and I can't edit yet.
Is there a way to pull the code history in an ECU, like a vagcom for Honda.
Don't mean to threadjack and I don't think I personally have any issues but I'd love to be able to verify.
HOW COME NO ONE EVER READS MY INPUT!??!?!?!?
a
I saw that and looked them up and they are $$
Was hoping there was something like the Vagcom tool for VWs that is the ODBII to USB where you could read the code history with a laptop.
And does the ECU store a history of every code every thrown or does it clear out if reset?
^ some codes are hard set and some clear out after a certain number of drive cycles or milage.
Only some TL would know the date and time (the ones with Navi) so wouldn't honda just record the engine hours that it happened at?
^correct, the freakin HDS tool from Honda.
only Honda and Acura dealers have this. no, you wont be able to buy it.
have them scan your car with the HDS.
Honda Diagnostic Scan tool, or something like that.
the fuck man, didnt you read!?
I believe the code is stored on the ECU and you will need the HDS to access this.
this is the 5th freaking time I mentioned the HDS, i swear no one reads.
if some one asks another question about the HDS...
