'08 TL-S Not reaching Operating Temperature
Hi Everyone,
as the title states my TL isn't reaching operating temperatures. I am assuming the Thermostat is stuck open and I'm looking to replace it.
Just want to know if anyones replaced it on their own? Is it a Big job and do we have any DIY?
Thanks for the help in advance.
Out of curiosity, is your temp needle sitting at about the 1/4 mark?
If so, then take a look at this thread:
https://acurazine.com/forums/problem...8-tl-s-923643/
if you let the car sit and idle, does it warm up? if so, does it cool off when you start moving? If yes to both then you got a t-stat issue and need to replace it.
the best way to test is set the heat on max and let it idle. if it gets hot and then cools off when you move, go straight to t-stat
MetalGearTypeS
Aug 29, 2016 08:28 PM
ExcelerateRep
Oct 14, 2015 08:20 AM
joflewbyu2
Oct 8, 2015 11:16 AM
AcuraKidd
Sep 25, 2015 11:18 PM
