'08 TL engine - motor mounts okay?
Old Oct 29, 2022 | 11:47 AM
Jpilk99's Avatar
Hi all,
My '08 TL's engine seemed (to me) to move more than it should when, with the brake firmly on, I put it in Drive or Reverse. Took a video and curious if this looks normal:
Also, not sure if you can hear the rattle I've been hearing. Seems to be coming from between the motor and firewall; likely just a heat shield... Just curious if anyone has dealt with similar.
Thank you,
Jay
Old Oct 29, 2022 | 10:41 PM
Ron A's Avatar
Administrator
The forum where you originally posted, the AcuraZine User Help, Support & Suggestions Area , is meant for problems, comments, and suggestions for the website itself, so I moved your thread to the car specific forum applicable to your vehicle.
This was explained in the sticky thread at the top of that forum, or click here if you can't find it, which will explain why you shouldn't have posted your thread there.
Old Nov 9, 2022 | 02:51 PM
Sacto Civic's Avatar
Looks like it’s probably time for motor mounts. Does it clunk when it downshifts with a load on it, like when accelerating up a hill and the car shifts from say 4th to 3rd gear? That was the most noticeable indicator in my 05 that the mounts were bad
Old Nov 9, 2022 | 04:57 PM
Jpilk99's Avatar
No clunks
KingTiger101
New Member Introductions
Aug 1, 2021 10:27 PM
Acco1st
Mar 23, 2021 01:12 PM
RichFlo
Apr 19, 2020 02:03 PM
obmkm2
Feb 13, 2018 07:55 AM
