Hi guys...
On my 07 TL base...a few months ago my drivers side door would not unlock from inside. Turns out the door lock actuator was the culprit. Swapped it and all was well.
Recently my memory buttins dont work...when I press Memory it beeps and the light flashes but when I hold 1 or 2 down there is no beep or light and it does not work
Also...in the past when I would need to move my drivers seat all the way forward or back...I would just hold the button and it would go all the way forward or back before I released it. Now...even if I hold the button to move the seat forward...it will move a little then stop. I would then to let go of the button and press it again and it would move a little before stopping again. It would take 3-4 repeated steps before it would move to the position I want.
Anyone got any ideas where to look? I did some research and it seemed peoples side mirrors also act up....but mine are fine...even when I reverse the side mirrors work fine....
This sounds like a problem with the seat control module. I think there was a TSB for this. Try looking it up. You can probably get a used one.Originally Posted by ZoneMan
Hi guys...On my 07 TL base...a few months ago my drivers side door would not unlock from inside. Turns out the door lock actuator was the culprit. Swapped it and all was well.
