Ok, I have around 20k on my car, the car started to shift VERY hard the first 2 or 3 gears when in auto. This only happens when the car is cold. Sometimes when I leave to go to work in the morning, the tranny will not shift to 2nd gear!! even if I go to sport shift and shift to 2nd, the indicator will indicate 2nd for a couple of seconds, but the car does not shift, and the indicator will go back to 1st. The car will just rev very high in 1st and after a 5 or 10 seconds, it will finally shift very hard into 2nd. Once when I was in sport shift mode and I manually shift into 2nd, there was even a clunking sound when it shifted, but that has only happened once. This happens only when the car is cold.. anyone have any ideas???
sounds like a bad modulator. Does anyone know if the TL has a vacuum modulator? If so, it could be a leaking vacuum hose as well.
acura master tech
well since it is under warranty. it needs to go to the dealer.sounds like a a-b switch or just a bad trans. there just like the 2nd gen trans but better gears, better cooling and shift points. but are kinda the same.we all know the problems with the 2nd gen.
I hate cars
close
- Join DateMar 2006
- LocationBakersfield
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,818 Times in 1,287 Posts
If it only happens when cold I would start by checking the fluid level.
Trew- no modulator and no TV cable. It's all electronic. I actually miss the simplicity of the older stuff.
Acura's 5AT SUX!!! they cant get it right. My 07 TL-S shutters when going real easy on the gas from 2nd to 3rd and 3rd to 4th, makes my car shake. When i bought it I thought the the tranny problems were only happening with the 2nd gens.
I cant believe i bought another Acura...
^ dunno what you're talking about. Going on 3 years and i've never had a problem - with ANYTHING.
Have u tried flushing ur tranny fluid. Try that GM tranny fluid, dunno if its right for 5AT,but I heard it works so who knows. My 3rd gear is having problems too, I should try out that stuff..hope it saves me a trip to the dealership! Good Luck!
csmeance
close
- Join DateFeb 2006
- LocationSpace Coast, FL
Liked:2,185 Times in 1,569 Posts
Quote:
GM Syncromesh = BAD!!!! for the 5AT TL. That is MANUAL transmission fluid, not AUTOMATIC. USE THE HONDA FLUID FOR 5ATOriginally Posted by JwongTLS
YeuEmMaiMai
close
- Join DateSep 2006
Liked:439 Times in 346 Posts
if your trans is acting up cold, it's toast
I have Amsoil tranny oil inside completely. Think that might be causing problems? shouldn't though...
01tl4tl
close
- Join DateSep 2006
- Age66
Liked:1,142 Times in 1,072 Posts
amsoil is ok and wont cause the problem- that anyone knows~
but most of the people using it are all higher mileage TL of gen2
Sounds like you have a bad clutch pack- when they replace the trans leave it on its honda fluid to be safe
