07-08 brembo caliper question ....
So I disassembled my front calipers to get sprayed brembo yellow, when I went and installed them and tried to bleed the brakes my driver caliper was leaking from the middle and not were u bleed from. So I took it apart and figured it was thru the hole in the picture below. So I can’t remember if it came with a o-ring or seal so I went to disassemble the passenger side (was not leaking on that side ) but when I went to loosen the 7mm Allen bolts that’s when it started leaking so I’m assuming I didn’t have the driver side tight enough? So is there not a seal/o-ring? Or do I just tighten it tighter ?
Does this need a o ring ?
buy a rebuild kit, which you should have done before taking them apart!!
https://www.partsgeek.com/gp1wd5v-ac...per+Repair+Kit
https://www.acurapartswarehouse.com/...epair_kit.html
https://www.rockauto.com/en/catalog/...epair+kit,1720
thoiboi (06-28-2019)
beekermartin
08-27-2014 06:54 PM
