'06 TL starting issue! Please help.
Old Jul 8, 2016 | 05:25 PM
Anthony Vasquez's Avatar
06 acura tl. Recently when I start the car up it takes a little longer to start. Not too long but longer than it used to. Is the battery going to die soon? Should I buy a new battery? Any help appreciated. Thank you.
Also more info it doesn't always take longer sometimes, it's just more frequent now and it doesn't it no matter how long it was sitting without being driven.
Old Jul 8, 2016 | 09:44 PM
Will Y.'s Avatar
Registered but harmless
Get the battery condition checked at a shop, or use a multi-meter or battery tester if you have one.
While checking the battery voltage, clean the clamp and terminal area of any corrosion and make sure the clamps are tight.
If the battery is more than three years old, it's suspect..
Check for an electrical drain an hour after the car has been shut off. If there is a drain, it's likely a failing HFL unit which is also draining the battery.
Welcome to AZ.
Old Jul 9, 2016 | 12:05 PM
Welcome to AZ.
Thanks for the welcome. Got it checked with my neighbor it was reading 5 volts. Autozone said it was dead
Got a new battery and everything's fine. Resetting the radio was a pain.
Flipster23
Norcal
262
May 4, 2023 02:47 PM
EE4Life
Dec 20, 2022 05:16 PM
EE4Life
Mar 12, 2020 07:29 PM
EE4Life
EE4Life
May 14, 2016 07:14 AM
