'06 TL squealing noise might be brakes? Need help
I understand this problem has probably been answered before but I find it frustrating working around this website so sorry if it's been answered. So basically to describe it the noise the nest I can, a squealing noise that sounds like it's coming from the brakes on the driver side cam be heard sometimes. When I turn the car on in the morning its heard when going in reverse and throughout the day it came be heard when going over a bump, sometimes while turning it came be heard too. When I hear it and apply the brakes it goes away or its not as loud. I'm not too experienced so I'm not sure how to diagnose the problem. The brake fluid is at an Alright level. Sometimes the noise is even heard when I'm on the freeway going 70 mph. Any help is appreciated.
Check the pads to be certain that they are not worn and the metal "wear"
sensor isn't contacting the rotor. Check to see if the pads are held properly
within the bracket, retainers, pins, shims etc. Have had some pads that will
make a noise when reversing first thing in morning, but the noise would
disappear when driving.
