05 AT Transmission Jerk
I'm having a issue with my base model 05 AT jerking when I put the car in reverse. I recently had the trans fluid changed and new motor mounts replaces. Could this be a transmission mount issue?
If you had someone replace all the motor mounts, they should have done the trans mount right then if it was bad.
Glorygang600
Jan 18, 2021 06:34 PM
