05 Tl transmission problem
Old Jun 27, 2010 | 09:20 PM
jad1217's Avatar
so i am about to buy a 05 tl with 66k on it. i was wondering what the transmission problems are with this car. i have heard the the 04 and earlier 05 had some problems. the car that i am buying was built in 7/05.
Old Jun 28, 2010 | 10:40 AM
dwb993's Avatar
Check the fluid for a brown discoloration and a burnt smell.
On your test drive, pay attention to the transition from 2nd-3rd and 3rd-4th gear for any slippage or jerkiness.
If you wind up purchasing, there are 2 solenoids on the side of the tranny that you should replace. Also, a fluid change would not hurt---search here for both procedures. The solenoids issue was posted by user "I Hate Cars", the fluid change procedures are in the 3G Garage.
Old Jun 28, 2010 | 12:25 PM
01tl4tl's Avatar
Im an 01 with the gen2 trans issues (on 2nd trans) which carried into 04 and 05
sometime in 05 there was a change made to the actual trans case- moving an external oiler installed under recall on the last 7 years of cars..to inside the case
those trans are better but not bulletproof--any car make with similar trans has similar problems
the things listed by last poster are valid--brown fluid is bad
not all will fail, and driving it right helps- avoid using SS mode to do max rpm downshifts into 3rd and 2nd--thats the weak point for heat and leads to failure
I would not buy one now without a trans extended warranty to past when I plan to sell it
anywhere after 50-60k miles is ripe for failure if its going to happen
While some cars go 140 and no prob..eventually it will wear out--they do that~
Old Jun 28, 2010 | 09:17 PM
jad1217's Avatar
the car has a 100k bumper to bumper warranty through acura so i am not worried but i will be keeping this car for a long time. i am going to change the solenoids. the car had a fluid and filter change 15k ago at the dealer (carfax). i might stil change it (3X3) when i get it. any other things to look out for in the car?
mada51589
Jan 9, 2025 04:40 PM
pstomps
Feb 20, 2017 03:29 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
