'05 TL mileage storage and 105k maintenance
Old Oct 20, 2014 | 02:18 PM
wangcheung05tl's Avatar
The instrument cluster on TL was swapped with an 06 cluster by the previous owner. Is the actual mileage stored in the computer or the cluster? will I just have to wait for a breakdown to know that I'm at 105k+ miles?
Old Oct 20, 2014 | 02:50 PM
the mileage is stored on cluster.
the swapped cluster will display something else than your true mileage.
if you wait till a break down at 105k miles, then you're too late.
serious engine damage can occur from the timing belt if it snaps.
you'll need to hound previous owner for correct mileage...
or change out Timing belt and water pump early.
Old Oct 20, 2014 | 07:54 PM
great! no way of knowing who previous owner was.
Old Oct 20, 2014 | 11:24 PM
BC2G's Avatar
Registered Big Dog
Take a look at the serpentine belt, does it look warn?
you can get a peek at the timing belt if you remove the passenger front wheel and look from below behind the crank pulley... not a great look...
Maybe you could try contacting local acura dealerships in the area the car originated and see if they have a record of the service history under the VIN.
Otherwise, do the 105k service... the amount of money ($700-$1400) for the TB Change and Water pump is well worth it to preserve your car
Old Oct 21, 2014 | 07:46 AM
BC2G had a great suggestion of seeing if Acura had any records of your car via VIN!
I definetly wouldnt chance it tho...
an '05 will have over 100k miles for sure.
Old Oct 21, 2014 | 10:20 AM
<<<@!1!@>>>
Yes I've been looking at the Aisin water pump kit which I saw on numerous posts here. would I need anything else that is not included in this kit:
Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive Amazon.com: Aisin TKH-002 Engine Timing Belt Kit with Water Pump: Automotive
Old Oct 21, 2014 | 10:25 AM
oops, I meant "would" and not "wouldnt"
glad you understood. and yes that Aisin kit has every thing you need
Old Oct 21, 2014 | 10:33 AM
rockstar143's Avatar
Even if it's not 105K...you're supposed to address after 7 years.
I'd be curious why the cluster was changed...maybe the motor was too? in which case, I'd HOPE they did the belt too...check VIN on engine and see if it matches your dash.
Old Oct 21, 2014 | 02:33 PM
Thanks. Hadn't thought of that.
Old Oct 21, 2014 | 03:11 PM
pohljm's Avatar
You will need two camshaft seals and a crankshaft seal and serpentine belt + honda coolant
Old Oct 21, 2014 | 03:42 PM
I was pretty sure the overall thought was that the camshaft seals would likely not need changing. Hope so, I didn't change mine!
08KBP_VA
Oct 22, 2019 01:55 PM
baelim
May 10, 2018 09:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
dirleton
20
Oct 16, 2015 01:48 PM
