05 TL Major Service - Switching from Synthetic Blend to Advanced Full Synthetic Oil?
Old 02-04-2022 | 07:52 PM
CenturionTL's Avatar
I have an 05 TL with 213,000 miles
If had a TLX I would most definitely use all OEM parts.
I've been using Pennzoil Synthetic Blend High Mileage
Pennzoil High Mileage 5 qt. 5W-20 550045203 - The Home Depot
I am contemplating Mobil 1 Advanced Full Synthetic High Mileage
Mobil 1 High Mileage Full Synthetic Motor Oil 5W-20, 5 Quart - Walmart.com
Will Mobil one expose leaks that were not showing or has the synthetic blend already done this? I'm a concerned about the rear main seal or anything else starting to show its ugly head, but on the other hand if they are not already leaking I want the Mobile one to get all around the seals and lube them...This is the dilemma, as the other seals on my TL when I was replacing them were all dry and hard.
I just did a major service on my TL, and performed the following:
-Replaced both cylinder head gaskets, replaced cylinder head bolt washers and cleaned both cylinder head covers inside and out
-Replaced all spark plug seals and the spark plugs
-Valve adjustment, loosened all exhaust valves, tightened 4/6 intake valves
-Cleaned all 6 fuel injectors and replaced their filter screens and cleaned both fuel rails
-Replaced front and rear camshaft thrust cover o-rings, OEM
-Replaced both PCV valve o-rings, OEM
-Replaced air intake filter and cabin filter
-Replaced neutral safety switch
-Replaced 3rd and 4th pressure switch
-Flushed power steering fluid and refilled with OEM
-Cleaned Intake manifold
-Replaced Upper and Lower intake manifold gasket
-Cleaned throttle body and replaced its gasket
-Cleaned EGR Valve and replaced its gasket
-Installed new Diehard AGM battery
-Installed new Trico Ice wiper blades
What I used to clean:
Amazon.com: Gumout 800002231 Carb and Choke Cleaner, 14 oz. : Automotive Amazon.com: Gumout 800002231 Carb and Choke Cleaner, 14 oz. : Automotive
Purple Power Degreaser, 1 Gallon - Walmart.com
Before:
After:
Old 02-04-2022 | 08:21 PM
This is how I cleaned the fuel injectors:
This is how I replaced the filters:
The replacement filter I used (I reused the stock o-rings and relubed them with engine oil):
Amazon.com: UREMCO 4-6 Fuel Injector Seal Kit, 1 Pack : Automotive Amazon.com: UREMCO 4-6 Fuel Injector Seal Kit, 1 Pack : Automotive
I was getting 14-15 mpg per the MID. I am hoping this worked as putting bottles of STP fuel cleaner in my gas tank did little to nothing.
Old 02-04-2022 | 08:43 PM
csmeance's Avatar
did you reseal the oil pump? THat's a common leaking point for the J-series engine.
Why did you do the headgasket? Looks like you got a lot of work done! Hows she driving?
CenturionTL (02-04-2022)
Old 02-04-2022 | 09:03 PM
Thanks,
I didn't take apart the timing belt so I didn't get to the oil pump seal.
The head gaskets were leaking. The car is running like butter. I'm hoping my fuel economy issue has also been resolved. Time will tell...
Old 02-04-2022 | 09:15 PM
peter6's Avatar
How did you do head gaskets without taking the timing apart? By any chance do you mean valve cover gaskets?
Use whatever, change on time, it will be fine. You can use regular, blend, synth, or even mix them together, and it won't hurt the car. I like to use penz plat or mobil1 and I change it every 5k. Could do much more but oil is cheap. Also get a decent oil filter.
Old 02-04-2022 | 09:22 PM
My mistake, I changed the cylinder head cover gaskets**
2003-2009 Acura Gasket, Head Cover 12341-RCA-A01 | Acura Parts Now
But I used Fel-Pro
Amazon.com: FEL-PRO VS 50607 R Valve Cover Gasket Set : Automotive Amazon.com: FEL-PRO VS 50607 R Valve Cover Gasket Set : Automotive
Old 02-05-2022 | 10:55 AM
truonghthe's Avatar
Originally Posted by CenturionTL
Just why lol? OEM cost actually cheaper. I hate those Fel-pro kit they will leak before you hit anther 105k miles. As far as full synthetic concern, I have Mobil 1 on all of my car, oil does not cause leak. It reveal the seal fail to do it job
Old 02-05-2022 | 01:45 PM
DMZ's Avatar
DMZ
Head a da Family
356K miles on NAPA 5W-20 synthetic (which is really Valvoline SynPower) since 7K miles. Sometimes I'll use Mobil 1 when I can get it on sale at Costco. Either a WIX Platinum or Mobil1 filter at each change using the M-104A filter, the wider one for the 2003 TL with more internal filtering area. Changed the rear main seal and O-Ring recently during my latest clutch and flywheel replacement. Can STILL do 0-60 in under 6 seconds!
Old 02-05-2022 | 05:39 PM
Where do you buy your OEM parts?
OEM TOTAL $98.50
Shopping Cart | Acura Parts Now
Fel-Pro Total: $30.69
Total savings over OEM: $67.81
With that $67.81 saved, I was able to get a new neutral safety switch (old one was slipping out of drive to neutral when driving):
Amazon.com: Standard Motor Products NS-330 Neutral Safety Switch : Automotive Amazon.com: Standard Motor Products NS-330 Neutral Safety Switch : Automotive
Old 02-05-2022 | 06:02 PM
peter6's Avatar
The trick is to not replace the washers since they never leak anyways.
Old 02-05-2022 | 06:54 PM
mine were hard, don't remember if it was leaking
But I do agree, OEM is better...but not the price of it.
Old 02-05-2022 | 07:06 PM
peter6's Avatar
No worries, it's always easier to do the job second time since you had previous practice :P
Old 02-05-2022 | 07:10 PM
jeffstlnote's Avatar
I thought these were the valve cover gaskets..https://www.oemacuraparts.com/oem-pa...er-12030ryea01 ... .mine are leaking and a shop game me an estimate of $229.78. To replace them, using
Amazon Amazon
, so oem wise I would use
https://www.acurapartsnow.com/oem-pa...MtMmwtdjYtZ2Fz
Not this? https://www.oemacuraparts.com/oem-pa...er-12030ryea01
Old 02-05-2022 | 07:34 PM
Originally Posted by jeffstlnote
I thought these were the valve cover gaskets..https://www.oemacuraparts.com/oem-pa...er-12030ryea01 ... .mine are leaking and a shop game me an estimate of $229.78. To replace them, using https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1, so oem wise I would use
Same thing.... the 12030-RYE-A01 is the combined set of 3 spark plug seals, 5 washer covers and cylinder head cover gasket. You need to buy 2 of them.
Old 02-05-2022 | 07:47 PM
Ok this X's 2 then... https://www.oemacuraparts.com/oem-pa...er-12030ryea01
Thanks! Just prefer the OEM...so wanted to be sure.
Old 02-05-2022 | 08:29 PM
truonghthe's Avatar
I always bought part in bulk, I bought all the seal back in 2018 before all the pricing increase lol I bought 8 set in total.
E.G I paid for a set OEM front upper control arm for $56 EA, OEM lower ball joint for $45 EA, LCA bushing for $25 each.
@sockr1 and @04WDPSeDaN can vouch how much spare parts I stocked at the house lmao. Even my local dealer Master Tech jokingly said I stock more part than their dealer.
04WDPSeDaN (02-20-2022)
Old 02-07-2022 | 10:09 AM
Your Huckleberry's Avatar
Elite
Where do you buy the lca bushings? The compliance bushings. I cannot find anywhere.
Old 02-07-2022 | 11:04 AM
peter6's Avatar
https://www.oemacuraparts.com/v-2005...ront-lower-arm
https://www.oemacuraparts.com/oem-pa...Y2LWdhcw%3D%3D
Old 02-11-2022 | 04:03 AM
I just changed oil and filled it with
Mobil 1 High Mileage 5W-20 Full Synthetic Motor Oil, 5 Quart
High Mileage 5W-20 Full Synthetic Motor Oil, 5 Quart 120768: Advance Auto Parts
and
Mobil 1 Mobil1 Premium Oil Filter
Mobil1 Premium Oil Filter M1-110A: Advance Auto Parts
If my rear main seal is filled with gunk which is preventing it from leaking and Mobil one cleans it out and it starts leaking.........
Old 02-11-2022 | 04:08 AM
Midnight Mystery's Avatar
Null and proud of it
Nothing a little JB weld can't fix
Old 02-13-2022 | 08:02 AM
DMZ's Avatar
DMZ
Head a da Family
rockauto.com. I have the Mevotech LCA compliance bushings for 3 years now, and they're still just fine. https://www.rockauto.com/en/moreinfo...sn=364&jsn=364
My original ones were cracked at 11K miles and the dealer replaced the lower control arms under warranty.
737 Jock
1G RDX (2007-2012)
20
09-07-2018 02:15 AM
I hate cars
01-18-2013 07:48 PM
spoolinq
04-28-2011 09:53 PM
mrl_tl
04-24-2011 06:53 PM
RKeatF1
09-29-2006 06:40 PM
