05 tl keeps dying need help!!
Old Feb 3, 2009 | 01:39 PM
musiclover's Avatar
got a new battery and that navigation delay recall but my car died again this morning. any suggestions
and my center console glovebox thing is broken but i dont see a light staying on could it be that. thanks
Old Feb 3, 2009 | 01:48 PM
Majofo's Avatar
You mean the two push compartments.. no.. there's no light or drain source there. Go to an auto parts store like Auto Zone and have them check your charging system and make sure that your alternator is okay and supplying sufficient charge to the battery. Also make sure your terminal connections are secure and clean any oxidation / sulfates on the terminals. Take a drive on the new battery to make sure it holds a good charge and see if the problem occurs again. The OE battery is notorious for dying after simple low drain uses like using radio for a few minutes / rolling up windows / changing seat position while the engine is off.
Old Feb 3, 2009 | 01:50 PM
Majofo's Avatar
Also.. when you say died.. you mean you try to turn it over and it just goes *click *click.. or does the engine attempt to turn over but doesn't??
Old Feb 3, 2009 | 03:56 PM
musiclover's Avatar
before it use to go click click but now i got a new battery and it has been working fine for a couple of weeks
the battery is not dead because everything still turns on but when i turn my key the engine wont start!!!!
Old Feb 3, 2009 | 05:32 PM
PeterUbers's Avatar
your starter may be cashed out... the actual electric starter
Old Feb 4, 2009 | 08:56 PM
dr-who's Avatar
Make sure your battery terminals are not loose. Just lightly jiggle it and see if it moves. It should not move.
The Acura technician that replaced my battery (under warantee) didnt tighten it properly and it did same thing. The loose connection only carries enough current to turn on the accessories but not to start the car.
MetalGearTypeS
Aug 29, 2016 08:28 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
DNS91
Sep 29, 2015 10:11 AM
