'05 TL : Have to turn the Key Multiple Times to Start Car
Old 04-16-2014, 09:30 PM
BigJLM1's Avatar
This has just been happening to me for the past week. I have to turn key multiple times to start and I have to do it quick. If not the car doesn't start up.
I recently changed the starter because the car wasn't starting. I noticed the started was bad when I gave it a few knocks to start. Now, I turn the key to start and nothing happens. The Nav, radio and everything is on except for the engine. I can usually twist the key back and forth... then engine will sometimes takes 3-4 times for this to start up.
I'm thinking it might be the ignition switch, anyone ever had this problem before ?
Old 04-17-2014, 07:00 AM
Turbonut's Avatar
I assume that when the key is turned to start, although accessories are on, there is no starter engagement, so don't rule out a bad starter/solenoid. Where did you get the replacement starter?
Make certain that the battery has 12+ volts, cables are clean and tight, and you can always test the voltage at the solenoid when trying to start, but if you hear a click when trying to start, I'd say bad starter/solenoid.
BigJLM1 (04-17-2014)
Old 04-17-2014, 02:00 PM
BigJLM1's Avatar
I needed a starter quickly, so I got a Duralast starter from Autozone. I'm going to test the voltage this week. What are some good starter brands ?
Old 04-17-2014, 07:24 PM
Turbonut's Avatar
AutoZone starters are hit and miss as the rebuild leaves a lot to be desired, but they do come with a warranty. A few years back a friend of my son's needed a starter for his Corolla, but after 3 AZ starters he got his money back and purchased one elsewhere.
Old 04-20-2014, 12:49 AM
3RDGENTL757's Avatar
Either you got a shitty starter or it be the starter relay
02-25-2020 09:57 AM
tman570
06-11-2019 07:56 AM
jordanboi
09-05-2015 01:33 AM
Quick Reply: '05 TL : Have to turn the Key Multiple Times to Start Car
