'05 TL A/C Compressor Switch...
Old Jul 11, 2016 | 07:59 PM
cameradude's Avatar
7th Gear
...anyone know which wires to connect to make the a/c clutch engage? There are 4 wires in the connector and I'm trying to add refrigerant because of a slow leak but the pressure isn't high enough for the clutch to kick in.
Tks
Old Jul 12, 2016 | 05:03 PM
cameradude's Avatar
7th Gear
...guess no one knows the answer to this or another way of getting to compressor to engage??
Old Jul 12, 2016 | 05:55 PM
shmobby's Avatar
probably best to rent the correct equipment to charge the system or take it to someone who has the right stuff. filling the A/C system is not like filling your gas tank...
Old Jul 12, 2016 | 10:02 PM
cameradude's Avatar
7th Gear
I've got the manifold guages and all. Just want to refill the system cause of a small leak in the evaporator but it's too hot now to work on it and will be a winter project. I'm just used to working on GM vehicles not imports...so I just wanted to know which two wires to jump.
Old Jul 13, 2016 | 10:21 AM
shmobby's Avatar
this might be helpful
Old Jul 13, 2016 | 12:23 PM
cameradude's Avatar
7th Gear
...tks but its not specific to the relays or compressor for an Acura TL. Their Osram relays have no diagrams on them so I wouldn't know which pins to short to force the a/c clutch to engage. Also there are 2 relays in the fuse box associated with the a/c...
Old Jul 14, 2016 | 09:39 AM
shmobby's Avatar
shmobby's Avatar
jump those on the relay socket and it should engage the clutch.
Old Jul 21, 2016 | 01:13 AM
cameradude's Avatar
7th Gear
...I did figure it out a couple of weeks back and got the system recharged again. Had to jump the compressor relay and the fan relay in the fuse box under the hood. She's blowing cold again for now. gonna stick the gages on it again this weekend to check and see if every thing is still the same or if it's leaked down a little.
Tks again shmobby for your help though!
Flipster23
Norcal
262
May 4, 2023 02:47 PM
EE4Life
Dec 20, 2022 05:16 PM
EE4Life
Mar 12, 2020 07:29 PM
EE4Life
EE4Life
May 14, 2016 07:14 AM
